Do Ctbus Connected Boards Need To Be Terminated?
Hi. Per the recommendation on another thread, I have connected the d/120jct-ls and d/41jct-ls to each other via ctbus.
I cannot tell from the dialogic documentation whether the boards need to be jumpered or not (jp2 termination). If so, it sounds like both need to be terminated. but there is also a note
Does anyone here know?
Thanks in advance,
Les
This is all that should be required.
Are both cards now detected by the Dialogic Configuration Manager? Are you able to use the voice ports on both cards?
