Trouble With V5 Script Running On V7
I have a script that was originally created in Voiceguide V5, we have since moved to a 12port dialogic card and are now running V7 of Voiceguide.
The general paths and structure of the vgs file works fine, however the VBS scripts always return a fail and won't allow us to continue to the next section even with valid account numbers or credit cards.
One of the sections in question is "[checkIDlenOrderGas]" the main part of this section works fine, the VGRUNRESULT file is written and if you enter in valid details you get the word "SUCCESS" displayed in this file (FAIL if you insert the wrong details)
However the VbsHoldPlay= section always determines it has failed and sends you into a loop which eventuaslly after 2 retries disconnects you.
Has anyone else had an issue? I have this script running on our old machine running V6 and it works perfectly.
Running on a Windows XP (SP3) Intel computer with 2GB RAM, full admin rights and plenty of Disk.
Ccpay8.zip
Could you please post a copy of VoiceGuide's Traces which capture the call, this will allow us to see what happened on the call.
Trace files are created in VG's \log\ subdirectory.
Indicate time of call so that we know where in the trace file to look.
For trace files look in VoiceGuide v7 \log\ subdirectory.
We will need to see the vgEngine trace capturing the call.
Trace shows the module [checkIDlenOrderGas] executes fine, with evaluation of len("$RV[GetClientId]") = 10 successful and script then goes onto module [chksumIDordergas].
[chksumIDordergas] is a VBScript module.
The ran script is saved in file: C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs
115927.296 6 6 script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs
and it looks like the script completes within a second:
115928.390 6 6 Process.HasExited is true (System.Diagnostics.Process (wscript))
115928.390 6 6 task completed. vgm=121, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
but no result file was created by the script:
115928.390 6 6 ExeResult_NextVgm has not been set. check for Result file.
115928.390 6 6 no result file returned from program (VGRUNRESULT_6.TXT).
Suggest you try running C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs to see if it creates the Result File or not. You can debug C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs by adding MsgBox statements to it, or if you have Enterprise license you can use Admin_TraceLogAdd ( http://www.voiceguide.com/vghelp/source/ht...tracelogadd.htm ) to add logging from VBScript in the vgEngine trace.
115927.281 6 6 state [checkIDlenOrderGas] Evaluate [len("$RV[GetClientId]") = 10]
115927.281 6 6 rv replace start: [len("$RV[GetClientId]") = 10]
115927.281 6 6 rvns: [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{C:\ElgasVGuide\Prod\}[scriptsPath]{C:\ElgasVGuide\Prod\}[$RV_STARTTIME]{2009-06-16 11:59:00}[$RV_DEVICEID]{6}[DlgcVoice]{dxxxB1C4}[DlgcNetwork]{dxxxB1C4}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\ElgasVGuide\Prod\}[$RV_CIDNUMBER]{}[Welcome]{0}[retrysetOrder_Input]{0}[retrysetOrder]{0}[retry
count]{0}[retrysetOrder2_Input]{0}[retrysetOrder2]{0}[retrycount2]{0}[retrysetOr
d
er3_Input]{0}[retrysetOrder3]{0}[retrycount3]{0}[OrderGasGetID]{0235114788}[Orde
r
GasGetID_PathTaken]{success}[Evaluate 50_Input]{"0235114788"}[Evaluate 50]{0235114788}[GetClientId]{0235114788}
115927.281 6 6 rv replace end: [len("0235114788") = 10]
115927.281 6 6 eval[len("0235114788") = 10]
115927.281 6 6 CreateInstance ScriptControl objSC is: [system.__ComObject]
115927.281 6 6 rvns add [checkIDlenOrderGas_Input]{len("0235114788") = 10}
115927.281 6 6 rvns add [checkIDlenOrderGas]{True}
115927.281 6 6 Eval Expr result:[True]
115927.281 6 6 path {True} found (at offset 3)
115927.281 6 6 FindNextVgmTitleInPathList: next module title is=[chksumIDordergas]
115927.281 6 6 t timer clear (force=False)
115927.281 6 6 RunModule start [Run VB Script,[chksumIDordergas],121]
115927.281 6 6 state [chksumIDordergas] type: VB Script, iRunWait=1
115927.281 6 6 rv replace start (strlen>500)
d
r
GasGetID_PathTaken]{success}[Evaluate 50_Input]{"0235114788"}[Evaluate 50]{0235114788}[GetClientId]{0235114788}[checkIDlenOrderGas_Input]{len("0235114788") = 10}[checkIDlenOrderGas]{True}
115927.296 6 6 delete existing: C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs
115927.296 6 6 current objVbsOrExeProcess=
115927.296 6 6 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs][] timeout=60 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
115927.296 6 6 objVbsOrExeProcess.Start call
115927.312 6 6 RunVBScriptFile just started. Handle=976, Id=1752, StartTime=16/06/2009 11:59:27 a.m., HasExited=False
115927.312 6 6 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_6_1.vbs], ProcessHandle=[976], VbsOrExeProcess.WorkingSet=[86016]
115927.312 6 6 RunModule_Script_AfterScriptStarted start
115927.312 6 6 waiting. iRunWait=1 (process:976)
115927.312 6 6 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
115928.390 4 6 timer EV_TIMEOUT_CHECKONSTATE
115928.390 4 6 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
115928.390 6 6 qScr run evScriptEvent EV_TIMEOUT_CHECKONSTATE, iActionID=0, crn=0[0|0|0|0|0][|||||]
115928.390 6 6 ScriptEvent EV_TIMEOUT_CHECKONSTATE ||
115928.390 6 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
In module [chksumIDordergas] you can try changing this line:
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
to this:
filename = "VGRUNRESULT_$RV_LINEID.TXT"
$RV_DEVICEID is not an officially supported $RV.
I cleared out the temp folder and tried running twice, the first time I keyed the number wrong and saw a resulting FAIL in the VGRUNRESULT File.
However the second time the VGRUNRESULT file came back with a SUCCESS, however I still got told it was not correct
Attached fresh copies, including the vbs file.
elgas_001.zip
The VGRUNRESULT file needs to be created in the same directory as the script itself (the .vgs file).
Looking at the VBScript it looks like the full path to the location of the written VGRUNRESULT file is not specified, so most likely the VGRUNRESULT file is not actually created in the same directory as the script itself when it is ran from VoiceGuide. (it is probably created in some Windows system or directory)
You should change the VBScript to include the full path to where the VGRUNRESULT file should be created.
