Database Column Names
Are the below column names (GUID/CallGUID) correct? The VG DB script creates these names, BUT if we use the linkfield, shouldn't the column names be the same in both tables. I have had issues where data from the tables are not in sync and the only thing I can assume is because the column names are different and the linkfield will not see them correctly
Jeff
CREATE TABLE CallQue
ID Int IDENTITY(1, 1) PRIMARY KEY,
GUID UniqueIdentifier,
CREATE TABLE PortToUse
CallID Int,
CallGUID UniqueIdentifier,
<OutDialQue_PortToUse_LinkField>GUID</OutDialQue_PortToUse_LinkField>
The column names as quoted are correct.
The CallGUID column stores the GUID from the referenced entry in the CallQue table.
The OutDialQue_PortToUse_LinkField config field does not actually specify the column name, it specifies the general approach/algorithms to use.
