Detect uncontactable numbers
When i ring someone there are 3 possible scenarios.
1. call answered
2. answer machine answers.
3. Special info -- i.e. bad number
What i would like to know is there any way possible of running a command that updates my database if the cal state is "special info" therefore marking all wrong/bad numbers in my database so that i don't have to waste time calling them again in the future? At the moment i just use a simple ACCESS database.
Question 2.
When an answer machine is detected when making outbound calls i simply want to hangup. Is there anyway of hanging up without having to wait for the answer machine message to play?
Could you please post a copy of VoiceGuide's Debug Printout which captures the call made to a telephone number which resulted in a Special Information Tone - then I can advise how to set up your system to detect the Special Information Tones (SIT tones) correctly.
Just specify "NONE" in the Answering Machine Message entry (leaving that entry blank has a similar effect).
105850.90 7 Waiting for a call...
105850.90 7 lineOpen(7)LineHandle=66085
105854.55 0 dial callque update id=916 next call time 0309231258
105854.57 0 dial callque DB update returned
105854.57 7 dial found entry: tel[105100442076356877] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\recruitment\answered-call-filter.vgs] am[NONE]
105854.57 7 Calling MakeCallEx(105100442076356877)
105854.57 7 Dialing: 105100442076356877
105854.57 7 MakeCall => 65999
105854.57 7 TapiCbTrigSet 65999 7002
105855.32 7 tapi Reply (LineEvReply) ok 65999 0
105855.32 7 TapiCbTrigClear
105855.32 7 linedevstate 2048 0 0
105855.32 7 callstate DIALTONE 66256 0 0
105855.34 7 callstate DIALING 66256 0 0
105855.34 7 callstate PROCEEDING 66256 0 0
105855.34 7 callinfo CALLEDID
105855.34 7 callinfo REASON
105855.34 7 Lev_CallerID [01423325554,]
105855.34 7 callinfo ORIGIN
105908.79 7 callstate SPECIALINFO 66256 8 0
Trace shows that the SIT tone was detected about 13 seconds after starting dialing, but that the SIT tone type was "Unknown".
v5.2 Beta3 onwards will end outgoing calls when a SIT tone is heard, and will save the information in the "OutDial" result files in VoiceGuide's \data\ subdirectory.
Details of that particular call would be saved in file: OutDial_SIT_Unknown.txt
Information from those files can then be used to update the dialing lists...
From the new (v5.2 Beta3 onwards) VG Help file:
The result of all outgoing calls placed by VoiceGuide will be saved in VoiceGuide's \data directory, in one of the following files:
OutDial_Contacted_Human.txt
List of calls answered by a real person.
OutDial_Contacted_AM.txt
List of calls answered by an answering machine.
OutDial_Contacted_Fax.txt
List of calls answered by a fax machine person.
OutDial_Uncontactable.txt
List of calls which were not answered.
OutDial_Uncontactable_OnDontDialList.txt
List of calls which were not made as the telephone number is on a "Don't call list".
OutDial_SIT_Reorder.txt
List of calls for which the Special Information Tone (Reorder) was played by the phone company.
OutDial_SIT_NoCircuit.txt
List of calls for which the Special Information Tone (No Circuit) was played by the phone company.
OutDial_SIT_CustIrReg.txt
List of calls for which the Special Information Tone (CustIrReg) was played by the phone company.
List of calls for which an unknown Special Information Tone was played by the phone company.
The syntax of above files will be the same as that of the ‘Out Dial’ file, except that the time and date will reflect the time the phone number was contacted or when the last call was made. This allows for easy re-queuing of lists of telephone numbers by simply copying files to OutDial_New.txt
I understand that voiceguide will now list all bad numbers in the TEXT file but what I would like to know would be how i can use the TEXT file to automatically update my database with the fact that these numbers are bad?
Is there anyway instead of voiceguide putting this info into a text file it could query my access database and update the corresponding record?
If this is not poss what else can be done please?
The intention is in future to set up an option to run a user specified VB Script every time a number is appended to any of the result files as well - and from this VB Script (within which you will be able to use RVs as well) any user-specific operations such as updating user-specific databases will be able to be done.
Still unclear whether this will make it into v5.1 release or not.
Did the new feature discussed here where voiceguide can run a chosen vb script when a number is apended to a results file get into the new version5 beta 3?
Partially, please see the sOnNotConnected field which can be part of the OutDial_New.xml input file.
In 5.1 Beta 3 sOnNotConnected can be a command or a name of a VB Script to run when the call attempt goes unanswered. Result Variables relating to the call just made may be used as part of the command or VB Script's name.
A new RV is also available:
$RV[OutDial_RetriesLeft]
Number of retries left for an outgoing call. If this is the last call attempt then this RV will have a value of 0.
THanks - can you tell me if there is a variable etc to use when there is a bad number (Special Info) so i can seperate numbers that have not answered from numbers that are bad?
Matt
$RV[OutDial_Result]
When the outgoing call has been answered or the number of retries has been used up this RV stores the type of outcome. Possible values are: Contacted_Human, Contacted_AM Contacted_Pager, Contacted_Fax, Uncontactable_OnDontDialList, SIT_Reorder, SIT_NoCircuit, SIT_CustIrReg, SIT_Unknown, SIT_Unavailable, Uncontactable_NoAnswer
ok great, thanks i am not sure what some of the results variables mean can you expand on them a bit.
SIT_Reorder,
SIT_NoCircuit,
SIT_CustIrReg,
SIT_Unknown,
SIT_Unavailable,
Also, where do i specify the .vgs script run when a call is not connected please as cannot see it anywhere on the voiceguide call queue screen.
Matt
The SIT_xxxxxxx names correspond directly to the different types of SIT (Special Info Tones) received...
OnConnected is not a VGS script - it can be a command (.exe/.com/.bat) or a VB script to run. It can only be defined at this stage when using the new XML style OutDial file. (please see Help file for more info on this).
Ok thanks so i take it all these SIT basically mean the number is bad?
When you say that i cannot specify a VGS script which i would use to use the database module to update my Access Database - How can this be done without the database module please?
Any examples of searching for the record by callednumber and updating the access data without using the database module would really help as am a bit lost.
Matt
Yes.
To start off with all of the telepnone numbers will be saved in the corresponding 'Dial Outcome' files as well, which lends itself to batch processing afterwards, but if it necessary to update some central database immediately as well then updating databases from vb script:
    ' Initialize Connection object.
    Set cnnDB = New ADODB.Connection
    strDBpath = "E:\test\test.mdb"
    ' Specify the Microsoft Jet 4.0 provider and then open the
    ' database specified in the strDBPath variable.
    With cnnDB
        .Provider = "Microsoft.Jet.OLEDB.4.0"
        .Open strDBpath
        ' Add your own code to work with database here.
    End With
    strSQL = "Select * from Table1"
    ' Initialize Recordset object.
    Set rs = New ADODB.Recordset
    With rs
        .Open strSQL, cnnDB, adOpenKeyset, adLockOptimistic
        .AddNew
        !test1 = Me!test1
        !test2 = Me!test2
        !test3 = Me!test3
        .Update
        .Close
    End With
    ' Close Connection object and destroy object variable.
    Set rs = Nothing
    cnnDB.Close
    Set cnnDB = Nothing
As for how to use arguments passed as paramteres when the VB Script is called see the WScript.Arguments object:
Eg: if calling :
myscript.vbs c:\temp
you can use:
WScript.Arguments.Count
which will = 1
WScript.Arguments(0)
which will = "c:\temp"
Dial Outcome files are:
ok, thanks for the help it is making a little more sense.
As recomended i have been on the web and done several tutorials on VBscript and have modified you code a bit but am still a little lost... Can you take a look and see what the error is now with it as all i want to do i search my database at the end of the call for the record that matches the number voiceguide dialed and insert the call results into one of the fields. It seems to be looking over complicated at the moment and i am sure when you see the code you will know exactly what needs altering. Please help me. THanks Matt
callresults.VBS
Is anyone going to reply? I would appreciate it as it is important..
ok thanks i just thought you could help as would probably have an example as this would have been done before with voiceguide and therefore be able to offer some help and save me learning a whole subject just to do one thing in voiceguide..
Any examples would be appreciated.
Matt
