Need Help In Perth! (will Pay!)
I have a great idea for a voiceguide script & access database system, but dont have the experience. I have been fiddling around trying to make my voiceguide queries access a database, but it hasn't worked yet (connect string or no connect string).
Is there anybody in Perth Western Australia who could spend a few hours going through this with me? Maybe any database programmers with a saturday or sunday off? I really need help, I've done enough research to no avail, so I need hands on advice.
email: jims@netspace.net.au
phone: 08 94197770
Email is preferred. I may be testing a script using my phone number! ;)
To use an Access Database you do not need a 'connect string' - just specify the filename and that's it.
Specifying queries is quite straightforward once you get the hang of it, have you had a look at the sample Customer Enquiry script which ships with VoiceGuide?
Can you describe what you want to do?
A pretty good book on SQL is:
"SQL Queries for Mere Mortals" by Michael J. Hernandez, John Viescas
ISBN 0201433362
I wish to check CID details on an access table early on in the script. Also I want to be able to connect to a inventory table, check availability, then if available, reduce the number by 1.
Are you saying that I dont need this connect string:ODBC;DRIVER={Microsoft Access Driver (*.mdb)}; To make the connection work?
Do I need to have the access database open for voiceguide to access it? Do I have to set timeout parameters so that VG has enough time to obtain the selected information? Do I need an earlier version of access? I have office XP
I look forward to some guidance!
That's all pretty straightforward...
No, you just specify the full filename of the MS Access database file (.mdb file)
No.
You can, but such query will take less then a second...
That's fine...
