Vb Script Syntax Checking
Is there a way to check syntax on VB scripts? One bug today that took about 30 minutes to find was a misspelled else spelled as "elese".
I spend a lot of time debugging simple syntax (I know others must as well) that is usually caught in the VB programs that I am using (Access, etc).
Will VG get a "syntax checker" in future versions?
Thanks.
In next release of the script designer there is a syntax checker for the VBScripts etc.
