Vbscript
hello,
bellow is my VBScript that I try to run it with my VG. the problem is, the VBScript module keep running until phone disconnected.
would you please take a look at it an let me know why I don't get any result from it? this VBS works fine with compiler.
Function dbconnection()
Dim ConnProviderName
Dim ConnDBFile
Dim ConnDBFolder
Dim ConnUserName
Dim ConnPassword
Dim ConnOption
ConnProviderName = "Microsoft.Jet.OLEDB.4.0"
ConnDBFile = "IVR_Announcement.mdb"
ConnDBFolder = ""
ConnUserName = ""
ConnPassword = ""
ConnOption = "Persist Security Info=False"
' Connect from ASP page use this Connect_String
Connect_String = "Provider=" & ConnProviderName & ";User ID=" & ConnUserName & ";Password=" & ConnPassword & ";Data Source=" & Server.MapPath(ConnDBFolder & ConnDBFile) & ";" & ConnOption
' Connect from other sources use this Connect_String
' Connect_String = "Provider=" & ConnProviderName & ";User ID=" & ConnUserName & ";Password=" & ConnPassword & ";Data Source=E:\Other\IVR\IVR_Announcement.mdb;" & ConnOption
Dim MyConn ' Database connection object
dbconnection = Connect_String
End Function
Sub GetAccessRecord()
Call GetCalendarRecordByCalledId("esa tara")
End Sub
Sub GetCalendarRecordByCalledId(CallerId)
' this function will select the record from calendar table based on CallerId Provided.
Dim Company_name
Dim Client_name
Dim Announcement_Date
Dim Announcement_Time
Dim Client_Phone
Dim File_Name
Dim Office_Email
Dim Announce_Status
Dim MyConn
Dim ResultSet
Dim Sql
MsgBox CallerId
' If you use this script from ASP page, use this funtion
Set MyConn = Server.CreateObject("ADODB.Connection")
' If you use this script from Macro, use this funtion
'Set MyConn = CreateObject("ADODB.Connection")
Set ResultSet = Server.CreateObject("ADODB.Recordset")
'Set ResultSet = CreateObject("ADODB.Recordset")
Dim Connection_string
Connection_string = dbconnection()
MyConn.Open Connection_string
If Err <> 0 Then
MsgBox "Error occured in Connection"
End If
Sql = "select * from calendar where CallerId & "4085555555"
ResultSet.Open Sql, MyConn
If Err <> 0 Then
MsgBox "Error Occured in Sql Query"
Else
Do While Not ResultSet.EOF
Company_name = ResultSet("Company_Name")
Client_name = ResultSet("Client_name")
Announcement_Date = ResultSet("Announcement_Date")
Announcement_Time = ResultSet("Announcement_Time")
Client_Phone = ResultSet("Client_Phone")
File_Name = ResultSet("File_Name")
Office_Email = ResultSet("Office_Email")
Announce_Status = ResultSet("Announce_Status")
'MsgBox Company_name & Client_name & Announcement_Date & Announcement_Time & Client_Phone & File_Name & Office_Email & Announce_Status
'Move to the next record in the recordset
ResultSet.MoveNext
Loop
End If
ResultSet.Close
Set ResultSet = Nothing
MyConn.Close
Set MyConn = Nothing
End Sub
vg.Run_ResultReturn $RV_LINEID, "[CN]{"Company_name"}[CLN]{"Client_nam"}"
set vg = Nothing
Set client = Nothing
Best way to debug VBScripts which are running from within VoiceGuide's Run VBScript module is to make calls to Admin_TraceLogAdd COM function throughout the VBScript. The Admin_TraceLogAdd entries are printed in the vgEngine log and you will then be able to look through the vgEngine log to track how the script executes and identify at what lines the script has any problems.
Also the expression returned by the vg.Run_ResultReturn function is an invalid expression.
In quotes script you have:
it should be something more like:
vg.Run_ResultReturn $RV_LINEID, "[CN]{" & Company_name & "}[CLN]{" & Client_nam & "}"
VBScript uses & to concatenate strings together.
