Internet Portal - Works On Some Versions?
I like the internet portal and was using it. It seems that some versions of VG it either works or not.
I think it has to do with the following code. I have seen another verision that was different here (maybe "VG" instead of "VoiceGuide"??) but I can't find my other version.
Any ideas? I ran cscript and the vbs from a command prompt and it hangs, I think here.
vg.Run_ResultReturn $RV_DEVICEID, strResultVariables
Set vg = Nothing
Does this have anything to do with "vgServices.dll"? I tried to regsvr32 the dll but it didn't find the entry point, like it was not a reall dll.
If you run the script that you quote using cscript then it would not work. Cscript would error out when it comes across $RV_DEVICEID as it does not know what $RV_DEVICEID is.
vgServices.dll is not a dll that you can register using regsvr32.
