Vbscript Runtime Error Class Doesnt Support Automation/invalid Proced
Hello Support team,
My engine is version 7
so I am following version 7 dialer_outdialerqueadd protocol
when i tried to do this
vg.Dialer_OutDialQueAdd "0768197898", "", "2009-03-04 4:45:00 PM", "9:00 AM", "5:00 PM", "", "", "Campaign a1", 1, "C:\temp\soundfiles\am.wav", "", "C:\project\sysgen\Faxsubject1.pdf","", "", "", 90, 2, 30, "", ""
adding the pdf a new column an error
"Class doesnt support automation : vg.Dialer_OutDialQUeAdd .."
but when I take out the pdf entry.. as in
vg.Dialer_OutDialQueAdd "0768197898", "", "2009-03-04 4:45:00 PM", "9:00 AM", "5:00 PM", "", "", "Campaign a1", 1, "C:\temp\soundfiles\am.wav", "", "", "", "", 90, 2, 30, "", ""
"it says Invalid procedure call or parameter : vg_Dialer_OutDialQueAdd.."
Ive gone back and forth with the parameters and all, its the same thing as posted in the Online Documentation
what am i missing? also if there was an invalid class error when i added pdf into the parameters, how can i add it into the parameters?
ANy response woul be greatly appreciated.
Thanks a lot!!!
Try this:
vg.Dialer_OutDialQueAdd "0768197898", "", "2009-03-04 4:45:00 PM", "1:00 AM", "11:00 PM", "", "", "Campaign a1", 1, "C:\temp\soundfiles\am.wav", "", "C:\project\sysgen\Faxsubject1.pdf", "", "", 90, 2, 30, "", "", ""
Looks like the example in Help file has a problem with it. We'll fix up the example in the next version update.
