Escalation Issues
I can not get escalation to work. I use the below and after there is no answer on the first number, VG hangs, wil not process any other calls and must be restarted. Logs attached
Jeff
<OutDialEntry>
<PhoneNumber>18187314522</PhoneNumber>
<OnAnswerLive>C:\Program Files\VoiceGuide\Scripts\test2rv.vgs</OnAnswerLive>
<OnAnswerMachine>retry</OnAnswerMachine>
<RetriesLeft>0</RetriesLeft>
<RetriesDelay>1</RetriesDelay>
<RV>[FilenameToPlay]{c:\stt\wav\633702496885427500.wav}</RV>
<Escalation>
<OutDialEntry>
<PhoneNumber>18188470215</PhoneNumber>
</OutDialEntry>
</Escalation>
</OutDialEntry>
Logs.zip
Please try adding this entry to the Config.xml <Dialer> section:
<OutDialQue_PortToUse_LinkField>GUID</OutDialQue_PortToUse_LinkField>
and then clean the CallQue and PortToUseTables, restart VoiceGuide, and reload he escalation call.
If you still have problems please .ZIP up and post traces as before.
