Calling Vg Functions Like Rvget_all Hangs
Hello Team support,
I am trying to call a vbscript file external that is when an event NO Answer is raised but it hangs. I tried logging it to a text file but nothing, it cannot pass through that line..
im doing like this....
sReturnValue1 = vg.RvGet_All(1)
and I believe it cannot even pass through creating the VG object, it hangs at that point, so it will never get into rvget_all
what should I do? what has gone wrong?
theres no syntax error in the vbscript , its specifed in the NOANSWER xml tag
Thanks a lot
Could you please post a copy of VoiceGuide's Trace Logs which capture the problem, this will allow us to see what happened
Trace files will are created in VG's \log\ subdirectory.
Please post the traces.
Hello Support Team,
Attached are the logs and a very simple vbscript, I just deleted all the unnecessary codes, the script just tries to create a VG object then following that logs a textmessage into a file to see if it passes through that
problem is it never logged anything.
0227_ktTel.zip
Thanks a lot for your help
Traces show that C:\nobodyap.vbs and C:\retriesnobodyap.vbs are ran at end of second call. I assume that the .RvGet_All calls are from those scripts.
We do not have source code for these scripts but please note that recommended use is: .RvGet_All($RV_LINEID), not .RvGet_All(1)
The $RV_LINEID will be replaced with appropriate LineId to ensure information form the corresponding line is retrieved.
Also at startup there are some errors visible:
170504.743 11 ERROR v7.0.3343.31893 (Wed 25/02/2009 17:43:06.27) thread_sockStatusLink_DoListen : Only one usage of each socket address (protocol/network address/port) is normally permitted
170506.915 5 ERROR v7.0.3343.31893 (Wed 25/02/2009 17:43:06.27) vgServices_InitAccess : There is already a listener on IP endpoint 0.0.0.0:7132.
170506.915 5 InitRemoting call
170506.915 5 InitRemoting start. in-code config. port=7139, name=vgServices, connect string=http://localhost:7139/vgIvrRemoting/vgServices
170506.915 5 note: use this http connect string in any web browser to obtain WSDL for this remoting service: http://localhost:7139/vgIvrRemoting/vgServices?WSDL
170506.930 5 0 ERROR v7.0.3343.31893 (Wed 25/02/2009 17:43:06.27) InitRemoting new HttpChannel(7139) : Only one usage of each socket address (protocol/network address/port) is normally permitted
If you see these errors that suggests that the last time VoiceGuide was ran it was not shutdown properly for some reason and you will still probably see a vgIvrService.exe listed in the task list - with that process still using the port connections that are ultimately used by the RvGet_All and other COM functions. If you are seeing such problems then you should first look into how these problems occur and resolve that first. You should not be seeing the software get into such a state on properly setup system.
Another explanation is that some other application on your system is using ports 7131, 7132 and 7139
171231.443 6 3 run StartRun_VbScriptOrExeEtc [C:\nobodyap.vbs], source=OnNotAnswered
171231.443 6 3 current objVbsOrExeProcess=System.Diagnostics.Process (cscript)
171231.443 6 3 current objVbsOrExeProcess details : id=5820, handle=11384, hasExited=True, startTime=27/02/2009 5:10:31 PM, exitTime=27/02/2009 5:10:31 PM
171231.443 6 3 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_3_OnNotAnswered_090227171231.vbs][] timeout=0 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
171231.443 6 3 objVbsOrExeProcess.Start call
171231.474 6 3 RunVBScriptFile just started. Handle=11352, Id=2580, StartTime=27/02/2009 5:12:31 PM, HasExited=False
171231.490 6 3 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_3_OnNotAnswered_090227171231.vbs], ProcessHandle=[11352], VbsOrExeProcess.WorkingSet=[643072]
171231.490 6 3 run ok [C:\Program Files\VoiceGuide\temp\vbs_3_OnNotAnswered_090227171231.vbs]
171231.490 6 3 dial DeleteFromOutDialQue ID=1
171231.490 6 3 run StartRun_VbScriptOrExeEtc [C:\retriesnobodyap.vbs], source=OnRetriesExhausted
171231.490 10 dial Db_Delete_Entry begin id=1 guid=4896c636-7257-4b25-bcf5-13252a4aea23
171231.490 6 3 current objVbsOrExeProcess=System.Diagnostics.Process (cscript)
171231.490 6 3 could not get info on previos process (objVbsOrExeProcess)
171231.490 6 3 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_3_OnRetriesExhausted_090227171231.vbs][] timeout=0 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
171231.490 6 3 objVbsOrExeProcess.Start call
171231.505 10 dial Db_Delete_Entry end id=1 guid=4896c636-7257-4b25-bcf5-13252a4aea23
171231.552 6 3 RunVBScriptFile just started. Handle=11328, Id=3632, StartTime=27/02/2009 5:12:31 PM, HasExited=False
171231.584 6 3 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_3_OnRetriesExhausted_090227171231.vbs], ProcessHandle=[11328], VbsOrExeProcess.WorkingSet=[1261568]
171231.584 6 3 run ok [C:\Program Files\VoiceGuide\temp\vbs_3_OnRetriesExhausted_090227171231.vbs]
