Help - I Need To Clear Out Callque Right Away.
I need to delete some entries from the callque to get rid of about 4 calls that VG is trying to make over and over for a fax of a pdf.
I opened the telephone number loaded and did a "delete * from callque" but the outbound calls are not going away. It keeps trying to send the same fax over and over since I can't get pdf to work yet.
I had to stop the service completely until I am able to delete the outbound calls. I would like to be able to selectively delete outbound calls (like just the 5551234 numbers and not the "good" ones).
Thanks!!
Please .ZIP up and post the VoiceGuide traces to let us see what is happening.
"delete * from callque" is not a valid SQL statement. Here is some info on how to write basic SQL Delete statements: http://en.wikipedia.org/wiki/Delete_(SQL)
You should familiarize yourself with the VoiceGuide's database tables are structured if you want to use the SQL queries to manipulate the entries in them directly.
Yes, sorry, you are right. I did a "delete from callque" from the telephone dialer and that cleared out the outbound calls being made.
I am now back to my pdf fax issue trying to get that to work. Thanks.
Deleting entries from CallQue table may not be sufficient unless you have explicitly changed the VoiceGuide database configuration to only use the CallQue table as store of outbound calls.
