Calendar
Hi do you have a sample sciprt of calendar management take appointenemt for instance?
Thank you.
Mh
Right now we do not have a sample script demonstratting that specific application.
Do you have a function spec of this IVR? If you can describe in detail what is required of this app then we could supply a sample of how to go about creating this app.
In fact I would like to build an app that enables people calling to VG to take an appointement.
The system would be able to check in the database (mysql) a free slot after having asked 2 or 3 question?
Do you see what I mean?
Can you indicate what each of the prompts/responses would be? Type out the actual text of what is spoken and the digits pressed by caller in response. We can then better see what type of input you expect from caller and how the system should respond to it.
