Setting Result Variable Using Vbscript
Im trying to use VBscript in order to set RV Variable but i tried many times without any result ( the RV variables don't change with the new value set into the vbscrit (using RvSet and/or RvSet_RvList commands)
I tried to the exampes included on voiceguide helpfile without any result.
Can anyone help me?
thanks in advance
Please post the VoiceGuide traces capturing the system startup and the call and the VoiceGuide script used.
Trace shows that you are using a Professional version of VoiceGuide, but are trying to use the COM interface calls.
The COM interface is only supported in the Enterprise version. Please see: http://www.voiceguide.com/vgFeatures.htm
This is why you see error messages in vgEngine trace when you try to use the RvSet_RvList CO function:
100334.437 13 7 rem RvSet_RvList [CallerNR]{}[CallerLV]{0}
100334.437 13 7 ERROR: COM interface not supported in this version.
