Percent
How do you say 25.24% in your Porduct?
The only way I can get close is using number and say 2524.
Erv
The speaking of percentages is not immediately supported in the "Say Numbers" module, but you can use two "Say Numbers" modules one after another to make the script do what you need:
Have the first Say Numbers module speak the number before the decimal point, then have the second Say Numbers module say "point", then speak the two digits after the decimal point and then say "percent".
This requires you to be able to split up a number into its pre-decimal and post-decimal components first.
Splitting of the number can be done using the split function of VBScript
in VBScript Module:
aTwoHalves = split("$RV[RetrievedNumber]")
vg.RvSet $RV_LINEID , "PreDecimal", aTwoHalves(0)
vg.RvSet $RV_LINEID , "PostDecimal", aTwoHalves(1)
set vg = Nothing
where $RV[RetrievedNumber] can be replaced by whatever Result Variable is the original number to be spoken as a percentage...
Then $RV[PreDecimal] can be used in the first Say Numbers module, and $RV[PostDecimal] can be used in the second Say Numbers module.
