Script Code Doesn't Work
What is wrong with this? I am always getting the failed path. Also, is there an easy way to debug VB script in VG (check for syntax, errors, result codes... etc)?
i = val("$RV_ENTEREDNUMBER")
if i < 11 then
sResult = "verify_passed"
else
sResult = "verify_failed"
end if
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
Please post the vgEngine trace capturing the call, we can then see what happened.
Try just double-clicking the VBScript file created by VoiceGuide. If there are errors in it then you will see a message box. The script is at: C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs - but check the vgEngine trace for name of script file if you dial in on a different line or change the script.
These vgEngine trace lines tell you which script file is the right one:
132550.484 6 1 copy of verification script ran: vbs_1_1.vbs
132550.484 6 1 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs][] timeout=0 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
I'd try changing line:
to:
i = $RV_ENTEREDNUMBER
