Send Mail Module
Hi i'm trying to send email using smtp.gmail.com. In the logs the mail seems to be sent correctly but I don't get any emails at the specified email adress. Please find below logs
Tkx
MH
log.zip
Have you tried to send the email through other SMTP servers? Best to first try using your own SMTP servers or the ISP's SMTP servers.
No errors are reported in the vgEngine trace so it does look like the SMTP you are using right now either accepted the message or the .NET layer is still trying to re-send it.
A WireShark trace would let you capture the SMTP communication to see exactly what happened.
If the email message was unable to be sent there should be a status message in the vgEngine trace with the error details.
In the Email module there is a retries and timeout settings, default values are 3 and 10 minutes, so if email sending was not successful the error message in log will appear after 40 minutes (in less those default settings are changed).
