Hi-phone Desktop Rs232
Hi every body,
I'm trying to realize a personal IVR system and I've bought a way2call HI-Phone desktop RS232, as suggested in 'Recommended hardware' section , but I have some configuration problem.
The phone device seems to be correctly installed.
At the end of the 'wizard' procedure the 'state' is 'line ID not found'.
My OS is windows xp home edition with sp3.
Thanks for your help.
Can you post some screenshots of what you are seeing?
Have you used any of the sample programs that came with the HI-Phone to confirm if the HI-Phone TAPI/Wave drivers were installed properly?
thanks for our attention,
in control panel of winxp the device results only in the 'audio controller' group of device.
If I start 'Test wizard' I can select 'Hi-phone Desktop RS232 0 - Unplugged' and push on 'Go' the log is :
H/W Capabilities word=00000000
H/W Ext. Capabilities word=00000000
S/W Version=1.3.4.9
F/W Version=0.00.00
S/N=
***** Handset already Off-Hook
Headset no. 2 in
Headset no. 1 in
Short Event: Code=000000f0 Data=00000000
In the 'Tapi setup' I can select 'Hi-phone Desktop RS232 0 - Unplugged' and configure it.
In the 'device select' box of 'Sound card switcher' it doesn't appear nothing and if I select 'use headset' it goes in error state.
When I start 'Drivers information' it shows:
Way2Call Drivers Information:
Package Version: 2.00.51
OS version: 5.1.2600 Service Pack 3
Device Information:
1. Hi-Phone Desktop RS232 0 - Unplugged
Firmware Version: 0.00.00
P/N:
S/N:
Software Components:
File: w2cUSBM.dll
Description: Way2Call Multiple Hi-Phone Devices DLL
Version: 1.3.4.9
Build: b001
File: ScTspML.tsp
Description: Way2Call Multiple Hi-Phone Devices TSP
Version: 2.00.51
Build: 0
File: w2cMultiOcx.ocx
Description: Way2call Multiple Hi-Phone Devices OCX
Version: 1.0.0.4
Build: 0
File: TestWiz.exe
Description: Way2Call Multiple Hi-Phone Devices Test Wizard
Version: 2.00.34
Build: 0
File: w2cMdSound.exe
Description: Way2Call Multiple Devices As Sound Cards
Version: 1.0.0.3
Build: 0
File: scwiz32.exe
Description: Way2Call Multiple Hi-Phone Devices PBX Wizard
Version: 2.00.34
Build: 0
File: w2cTspSetup.exe
Description: Way2call TAPI Setup
Version: 1.0.0.1
Build: 0
File: \drivers\ScIPTsa.sys
Description: WDM Driver for Serial IP Telephony Adapter - Hi-Phone
Version: 2.5.1.72
Build: multiple wave
File: w2cRS232Wave.drv
Description: Way2Call Hi-Phone Desktop RS232 Wave Driver
Version: 1.0.2.1
Build: 0
File: w2cUsb.dll
Description: Hi-Phone User Mode Device Driver
Version: 2.0.9.1
Build: b0002
File: ml_setup.exe
Description: Way2call Multiple Hi-Phone Devices Drivers installer
Version: 2.0.0.41
Build: b001
File: w2cMultiInfo.exe
Description: Way2Call drivers infromation
Version: 1.0.0.3
Build: 0
Audio IN devices:
0. Realtek HD Audio input
1. Hi-Phone Desktop Serial 0
Audio OUT devices:
0. Realtek HD Audio output
Thank you
Michele
Are you able to use any of the demo apps that come with this device to confirm that it is correctly setup and configured? Any apps that would allow you to confirm that the device can answer calls and play/record/etc ?
