Vbscript Compilation Error? Please Help
hi
i wrote my VBscript in which i invoqued a function from a
DLL by declaring it like this:
Public Declare Function Select Lib "./mydll.dll" (ByVal Port As String) As Integer
But when executing the script it raises the next message of compilation error :
C:\Project\Codage\myScript.vbs(14, 16) Microsoft VBScript compilation error: Expected end of statement
ps : (14, 16) is 14 ligne and 16 colum as indicated above by " ^ " caracter
thanks in advance for help ASAP
It's not supported purely through VBScript.
There are a few options if you're determined to do it:
1) API calls that don't require complex structures can be called through RUNDLL32.EXE
2) You can build a simple Automation object (COM/OLE) which imports the API call, and allows script access to it by way of an object method - just create an instance of your object first wherever you want it to run the method.
