Error When I Run Voiceguide
When I run VoiceGuide Dialogic 6.0.0.3386, this massage appear:
Run-time error '339'
Component 'ktTel.ocx' or one of its dependencies not correctly registered: a file is missing or invalid.
OS: Winxp professional SP2
VG: Dialogic 6.0.0.3386
Card: d/41JCT-LS
driver: System Relase 5
Framework dot net v3
Which version Dialogic drives is installed on this system?
As a minimum you should have SR5.1.1 SP1
Is the Dialogic card detected and shows up in the Dialogic Configuration Manager?
BTW. We'd recommend using VoiceGuide v7 - you will get better sound quality with v7. For v7 you can use the SR6.0 drivers - link is on our WWW next to v7 Download link.
