Using Voiceguide Without Having To Call
Hi
I would like to know whether it is possible to use Voiceguide scripts without having to call the phone to which the IVR board it is plugged to. In other words, i want to bypass the calling and answering part to quickly test new scripts without requiring a separate phone for calling.
Please advise.
You can setup VoiceGuide v7 in VoIP mode, which then would let you test the system by dialing into it from another VoIP softphone. This way you do not need to use a physical card and phone to make the test calls.
