If I Have Two Objects In Script Designer And A Vbscrip In Each One, So
Dear Gentlemen,
We company's MOBLINK mobile solutions installed in Brazil, my name is
Clésio. Install the version 6.0.3386 Working Trial Version, but when we are
modeling our application, using the Script Designer, it does not run script
written by more than an object(module).
Example: If you write an object in script "Capture Entered Number" and
another script object in the "Run VB Script," he runs just one of them.
When this script runs...
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("c:\output1.txt", ForAppending, True)
tsFile.WriteLine "FILE LOGIN 1: $RV[PEDE LOGIN]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
This one does not run...
set tsFile = fso.OpenTextFile("c:\output2.txt", ForAppending, True)
tsFile.WriteLine "FILE LOGIN 2: $RV[PEDE LOGIN]"
tsFile.Close
set fso = Nothing
Only a script runs at a time when we use two scripts at the same time, he always runs the first.
We'd like to know whether the registered version does not have this problem.
Thank you.
Clésio de Miranda - Systems Analyst.
clesio@moblink.com.br
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=0
ktTts=0
