Vg & Voip --> Sip 401 Unauthorized Error
I have problems to connect to an asterisk server... "SIP Status: 401 Unauthorized Error"
My asterisk server ip: 192.168.6.11
My VG server ip: 192.168.6.5
user: 901
pswd: 901
VG 7.0.8
hmp3.0SU225
server win 2003
I ran the wireshark (log: sip.txt)
After that, I installed and ran a softphone succesfull with the same account... (log: 2008-11-24 Express Talk Log.txt)
Can you help me???
Thanks,
Rudyard Moreno
logs.zip
Could you please post the WireShark trace as a .pcap file - the full SIP packets' contents are not shown in the .txt dump provided.
You can try changing:
<Domain>192.168.6.11</Domain>
to
<Domain>asterisk</Domain>
This would make the Config.xml section:
<VoIP_Lines>
<VoIP_Registrations>
<VoIP_Registration>
<Display>901</Display>
<Protocol>SIP</Protocol>
<RegServer>192.168.6.11</RegServer>
<RegClient>901@192.168.6.11</RegClient>
<LocalAlias>sip:901@192.168.6.5:5060</LocalAlias>
</VoIP_Registration>
</VoIP_Registrations>
<VoIP_Authentications>
<VoIP_Authentication>
<Username></Username>
<AuthUsername>901</AuthUsername>
<AuthPassword>901</AuthPassword>
</VoIP_Authentication>
</VoIP_Authentications>
</VoIP_Lines>
WireShark trace shows that the SIP registration is now OK (see packets 994-1000), and calls for "901" are being sent to 192.168.6.5:5060 address (192.168.6.5 is system where VoiceGuide is installed) (see packets 1106-1215).
Question now is why the SIP INVITES are not being answered by HMP/VoiceGuide.
Could you please post the ktTel and VgEngine traces as well as the WireShark .pcap trace and we can then see why the incoming calls are not being answered.
It works!!! I find the error in the path because the config.xml is in english and my windows is in spanish...
Thanks,
Rudyard Moreno
OK, thanks for letting us know it's working.
Please let us know if there is anything else we can assist with in the future.
