Voice Recording
I would like to know if it is possible to setup a voice recording application using VG.
What I would like to to is when having externat calls, be able to record them.
How can I hande that ? Can I use dialogic boards to do that ?
Thank you
Mz
This means that I have to use two ports from the dialogic card for each call?
Examaple, If have 2 external lines and if I want to record all communcaition :
Incomming calls:
--> Do I have to plug these 2 lignes on my dialogic board? and then make a blind transfert on the called number ?
--> Outgoing call:
When I make a call should I do it on the dialogic port then make a blind transfer to the external number ?
What is the schemea that you advise for such configuration ?
Tkx
Mh
Yes. A Blind "Dial and Conference" transfer.
Call the Dialoigc card, have the script do a Blind "Dial and Conference" transfer to ans external line. You will then hear the eternal dial signal from our PBX/Telco. Then dial the number as usual.
Both scripts would consist of just a "Dial and Conference" transfer module and of the
