Directory Path Problem
Hi
I am using the following script to insert into MYSQL database with the help of Query Database module
INSERT INTO CONTACTDB.CASES (CALL_TIME,CALLER_ID,CASE_PATH) VALUES('$RV_STARTTIME','$RV_CIDNUMBER','$RV[LmRecDirectory]')
The data is getting inserted. But here I am using a variable $RV[LmRecDirectory]
This varible contains a directory path
113606.796 22 7 comlg CPS Data: DataPath: 9989505111_1031113606
113606.796 22 7 comlg CPS Data: Directory Path: C:\Chatline\scripts\CpsData\9989505111_1031113606
113606.812 22 7 rem Run_ResultReturn [[LmRecDirectory]{C:\Chatline\scripts\CpsData\9989505111_1031113606}]
113606.812 22 7 rvns add [LmRecDirectory]{C:\Chatline\scripts\CpsData\9989505111_1031113606}
113606.812 22 7 FindNextVgmTitleInPathList: next module title is=[LmSetSilenceDetectLen]
But what is happening here is this data is getting inserted as C:ChatlinescriptsCpsData9989505111_1031104844
The " \ " character is getting escaped and inserted into the databse.
I have searched the forum but couldn't find any post related to such problem
Hi
The problem is solved its the problem with database
If we insert C:\\Chatline\\scripts\\CpsData\\9989505111_1031113606 i,e use a double slash its working.
