Transferring A Fax Call
Due to the difficulties with FAX and the Dialogic cards I would like to setup a couple of extensions on my PBX to go to standard PC fax cards. Is there anyway to have VG transfer a call to those other extensions when an incoming FAX call is received?
from v5.1 Beta3 onwards you will be able to use a path:
on {fax} goto [Destination Module]
which will be taken if a fax calling tone is detected.
