Using Vg.script_goto
When I use VBS:
vg.Script_Goto $RV_LINEID, "my_file.vgs","my_Module","[Favorites_ID]{}"
It's working, but when left blank 'sDestModule' not working , like this:
vg.Script_Goto $RV_LINEID, "my_file.vgs","[Favorites_ID]{}"
or
vg.Script_Goto $RV_LINEID, "my_file.vgs", , "[Favorites_ID]{}"
or
vg.Script_Goto $RV_LINEID, "my_file.vgs","", "[Favorites_ID]{}"
or
vg.Script_Goto $RV_LINEID, "my_file.vgs|","[Favorites_ID]{}"
or
vg.Script_Goto $RV_LINEID, "my_file.vgs|", , "[Favorites_ID]{}"
or
vg.Script_Goto $RV_LINEID, "my_file.vgs|","", "[Favorites_ID]{}"
I want left blank 'sDestModule' and sending Vars in the same time.
Your third variation should work:
vg.Script_Goto $RV_LINEID, "my_file.vgs", "", "[Favorites_ID]{}"
If you still have problems please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened.
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=10
ktTts=0
