Another Call Arriving After Last Call Finished
test_123 wrote:
Dear Support,
There is one behavior I don't know why it happened and don't know where I can control. After a script finished the program hang up the call. After unknow period of time (sometimes 2-3 minutes, sometimes several seconds) another script starts to kick in.
I attached a piece of log here. It contains two tries. One starts at around 1765906. At 170409.36 program called hangupCall. Things after that I don't know why it happened. Somehow ugi_onanswer.vgs is involved (171030.81), and the ugi_onfinish_1.vgs is ugi_onanswer.vgs's finish script. I don't know if they are linked somehow even though there is some time gap. Why they showed up in the log, I have no idea.
I then removed ugi_onfinish_1.vgs from ugi_onanswer.vgs's finish script. And run the program again. Look at the log, it started at 171310.88. At 171430.30 program finish and hangup the call. But after that at
171436.88 1 rvns add [scriptsPath]{C:\toa\callout\UGI_trial\}
I don't intend this to happen. It seems to me something need to be fired up on event
171433.89 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900.
But where is this defined? Can you give me some idea? Or I am totally on the wrong track to use the product? Thanks for your any help. If you need any other information, please let me know.
Ronghui
log.txt
There seems to be chunks missing form your log file. Here is an excerpt from your log file. As you can see a lot of time is missing between these two lines:
170143.77 1 RunModule start [Run vb script:[C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs]
170410.39 1 FindFullPathToScript_VgsOrVgp start [C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs]
and these two lines:
170410.67 1 RunModule start [Run vb script:[]
171431.42 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
170143.48 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
170143.77 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
170143.77 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
170143.77 1 init atidle reinit : start
170143.77 1 starting AfterHangup script
170410.39 0 LoadedVgs_Find C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs at idx=2
170410.39 1 setting .iVgmIdx_AfterHangupRun=18, .iVgsIdx_AfterHangupRun=2
170410.39 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
170410.67 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
170410.67 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
170410.67 1 init atidle reinit : start
170410.67 1 starting AfterHangup script
171431.70 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
171431.70 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
171431.70 1 init atidle reinit : start
171431.70 1 init atidle reinit iConferenceOtherLegLid=-1
The log entries that you refer to at 171310.88 are not even in the supplied trace...
At 171436 we just see that the Dialogic card has detected a new call arriving on system:
171436.88 1 event callstate OFFERING 1 2,0,0
171436.88 1 script interpretor: VgMulti v6.0.3379
171436.88 1 fired OFFERING event to listeners
If no call was placed into the system then there may be something wrong with the card's call detection circuitry, or with the phone lines themselves.
Suggest you try plugging different lines into the system or plugging the lines into different ports on the Dialogic card and to isolate the cause of error by a series of tests with different configurations and see which work and which do not.
Thanks for your reply. You may point to a very important clue. Once my coworker said the line I was using may be strange. It has DSL capability although we didn't subsribe the service. I will use another line to test and see if I still have this problem. Attached is the log again. The behavior of hang up for the two calls are different also. First one called ugi_onanswer.vgs
171030.81 load start [C:\toa\callout\UGI_trial\ugi_onanswer.vgs]
The second didn't indicate which script it picked but seems start with
171440.70 1 state [FromUGI] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
Although it told the path, I didn't see which vgs it picked up. But the wav file is from a different script other than ugi_onanswer.vgs.
Anyway the behavior is strange. I will try more and see if I can isolate the problem.
*******Following is my first message**********************************************************
165906.52 load start [c:\toa\callout\UGI_trial\ugi_trial1.vgs]
165906.52 MemStructVgs_ClearVgs [5]
165906.61 load end
165906.61 loaded Script Id 5: c:\toa\callout\UGI_trial\ugi_trial1.vgs
165906.61 0 Erasing Script (new loaded) Id 3
165906.61 0 VgsScriptFree [3]
165906.61 MemStructVgs_ClearVgs [3]
165934.81 1 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
165934.81 1 event DISCONNECT_TAPI2, iCode=134 state=900
165934.81 1 LsAwaitingCalls EV_UNKNOWN_134
165934.81 1 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
165934.81 1 already IDLE. HangupCall ignored.
165934.81 1 init atidle reinit : start
165934.81 1 init atidle reinit iConferenceOtherLegLid=-1
165934.81 1 init atidle reinit : reset all LineState variables
165934.81 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
165934.81 1 state Waiting for a call...
165934.81 1 event TDX_CST, iCode=134 state=900
165936.91 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
165936.91 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
165936.91 1 setting iDialoutReadyToDialout = 1
165955.50 1 dial [184,3231112,808181659,0,2359,MoTuWeThFrSaSu,[],1,c:\toa\callout\UGI_trial\1651152.wav,c:\toa\callout\UGI_trial\ugi_trial1.vgs,c:\toa\callout\UGI_trial\ugi_am1.vgs,[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{
ally}[LastName]{Tan}[Jobdesc]{Building Maint.}[Token]{init}[CallBackPhone]{1234567},29,0,5,c:\toa\callout\UGI_trial\ugi_notcon.vgs,] (search started at 165955.50)
165955.50 1 dial DialOnLine start tel[3231112] ann[c:\toa\callout\UGI_trial\1651152.wav] vgs[c:\toa\callout\UGI_trial\ugi_trial1.vgs] am[c:\toa\callout\UGI_trial\ugi_am1.vgs] rv[[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{Sally}[LastNam
]{Tan}[Jobdesc]{Building Maint.}[Token]{init}[CallBackPhone]{1234567}] cid[]
165955.50 0 dial callque update id=184: NextCallTime=0808181704(8/18/2008 5:04:55 PM), RetriesLeft=-1
165955.50 1 rv clear all
165955.50 1 rv add [PhoneNumberCalled]{3231112}
165955.50 1 rv add [TOAID]{100}
165955.50 1 rv add [JOBID]{24}
165955.50 1 rv add [FirstName]{Sally}
165955.50 1 rv add [LastName]{Tan}
165955.50 1 rv add [Jobdesc]{Building Maint.}
165955.50 1 rv add [Token]{init}
165955.50 1 rv add [CallBackPhone]{1234567}
165955.50 1 rv add [OutDial_ID]{184}
165955.50 1 rv add [OutDial_OnNotConnected]{c:\toa\callout\UGI_trial\ugi_notcon.vgs}
165955.50 1 rv add [OutDial_AnswerTimeout]{29}
165955.50 1 rv add [OutDial_RetriesLeft]{0}
165955.50 1 rv add [OutDial_PauseBetweenRetries]{5}
165955.50 1 dial making call tel[3231112] ann[c:\toa\callout\UGI_trial\1651152.wav] vgs[c:\toa\callout\UGI_trial\ugi_trial1.vgs] am[c:\toa\callout\UGI_trial\ugi_am1.vgs] OnHangup[C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs] rv[[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{Sally}[LastNam
]{Tan}[Jobdesc]{Building Maint.}[Token]{init}[CallBackPhone]{1234567}[OutDial_ID]{184}[OutDial_OnNotConne
ted]{c:\toa\callout\UGI_trial\ugi_notcon.vgs}[OutDial_AnswerTimeout]{29}[OutDial_RetriesLeft]{0}[OutDial_
auseBetweenRetries]{5}]
165955.50 1 script interpretor: VgMulti v6.0.3379
165955.50 1 state Dialing 3231112
165955.52 1 lineMakeCall=>[]
165955.52 1 timer set 39 EV_TIMEOUT_MAKECALL_NORESPONSE
165956.06 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
165956.06 1 event TDX_SETHOOK, iCode=135 state=5200
165956.06 1 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
165956.06 1 tw DialogicEvent 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
165956.06 1 event RLS_LCSENSE, iCode=135 state=5200
165956.06 1 LsWaitAfterDialingOut : 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
165956.06 1 Loop Current Sensing reported LC=OFF. Ignored as LoopCurrentReqBeforeDialing=0
165956.06 1 to turn on Loop Current Sensing set in VG.INI, [VGDialer] LoopCurrentReqBeforeDialing=1
170020.45 1 tw DialogicEvent 133,TDX_CALLP,10,4,0,TDX_CALLP,CR_CNCT,CON_PAMD
170020.45 1 event AM, iCode=133 state=5200
170020.45 1 LsWaitAfterDialingOut : 133,AM,10,4,0,CR_CNCT,CON_PAMD,
170020.45 1 event CONNECT, iCode=133 state=5200
170020.45 1 LsWaitAfterDialingOut : 133,CONNECT,10,4,0,CR_CNCT,CON_PAMD,
170020.45 1 event CON_PAMD, iCode=133 state=5200
170020.47 1 LsWaitAfterDialingOut : 133,CON_PAMD,10,4,0,CR_CNCT,CON_PAMD,
170020.47 1 event CR_CNCT, iCode=133 state=5200
170020.47 1 LsWaitAfterDialingOut : 133,CR_CNCT,10,4,0,CON_PAMD,,
170020.47 1 event TDX_CALLP, iCode=133 state=5200
170020.47 1 LsWaitAfterDialingOut : 133,TDX_CALLP,10,4,0,CR_CNCT,CON_PAMD,
170020.47 1 StartPlayingAnsweringMachineMessage hCall=206187, params=10,4,0
170020.47 0 dial callque delete id=184 (MSAccess)
170020.48 1 rvns add [OutDial_Result]{Contacted_AM}
170020.48 1 set LineState().hCall = 206187 in StartPlayingAnsweringMachineMessage
170020.48 1 state AM - wait for end of welcome message...
170020.48 1 dial awaiting end of answering machine message (lvl:10 for 20)
170020.50 1 RecStart [C:\Program Files\VoiceGuide\temp\RecAm_1.wav] ok, RecStartTime=61220.48
170020.50 1 timer set 120 EV_TIMEOUT_HANGUP
170020.50 1 tw DialogicEvent 134,TDX_CST,61960,0,0,DE_LCON,,
170020.50 1 event TDX_CST, iCode=134 state=1152
170020.50 1 LsDialoutRecAnswerMachineWelcMsg EV_UNKNOWN_134
170034.23 1 event EV_SILENCE_DETECTED, iCode=9300 state=1152
170034.23 1 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
170034.23 1 rec RecSoundStop ok
170034.23 1 RecEndTime=61234.23, RecStartTime=61220.48, Diff=13.75
170034.23 1 rv rec length: AmWelcMsg_RecLen100ms = 138
170034.23 1 rv add [AmWelcMsg_RecLen100ms]{138}
170034.23 1 timer set 1 EV_REC_FINISHED
170034.23 1 tw DialogicEvent 130,TDX_RECORD,0,0,0,TM_MAXSIL,,
170034.23 1 event TDX_RECORD, iCode=130 state=1152
170034.23 1 LsDialoutRecAnswerMachineWelcMsg EV_UNKNOWN_130
170034.27 1 event EV_REC_FINISHED, iCode=8003 state=1152
170034.27 1 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
170034.27 1 rv replace start: [$RV[AmWelcMsg_RecLen100ms]]
170034.27 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{Sally}[Last
ame]{Tan}[Jobdesc]{Building Maint.}[Token]{init}[CallBackPhone]{1234567}[OutDial_ID]{184}[OutDial_OnNotConne
auseBetweenRetries]{5}[OutDial_Result]{Contacted_AM}[AmWelcMsg_RecLen100ms]{138}
170034.27 1 rv replace end: [138]
170034.27 1 state Run Answer Machine script [c:\toa\callout\UGI_trial\ugi_am1.vgs]
170034.27 1 tr NewVgsVgm_Goto (c:\toa\callout\UGI_trial\ugi_am1.vgs,,,,,0)
170034.27 1 rv add [scriptEnd_Time]{8/18/2008 5:00:34 PM}
170034.27 1 rv add [scriptEnd_Goto_Script]{c:\toa\callout\UGI_trial\ugi_am1.vgs}
170034.27 1 rv add [scriptEnd_Goto_Module]{}
170034.27 1 rv add [scriptStart_Time]{8/18/2008 5:00:34 PM}
170034.27 1 rv add [scriptStart_CalledFrom_Module]{UpdateTOA}
170034.27 1 FindFullPathToScript_VgsOrVgp start [c:\toa\callout\UGI_trial\ugi_am1.vgs]
170034.27 load start [c:\toa\callout\UGI_trial\ugi_am1.vgs]
170034.27 MemStructVgs_ClearVgs [3]
170034.28 load end
170034.28 1 loaded [c:\toa\callout\UGI_trial\ugi_am1.vgs] into:3
170034.28 1 rvns add [scriptsPath]{c:\toa\callout\UGI_trial\}
170034.28 1 rvns add [scriptPath]{c:\toa\callout\UGI_trial\}
170034.28 1 StartModuleDefault=[Play 16]
170034.28 1 RunModule start [Play,[Play 16],26,,]
170034.28 1 timer clear bForceClear=False
170034.28 1 Play Module start
170034.28 1 state [Play 16] Playing
170034.28 1 state [Play 16] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
170034.30 1 play start ok, lPlayId=220000
170034.31 2 tr NewVgsVgm_Goto end
170039.38 1 tw PlayEnd 1 220000
170039.38 1 play end id=220000, (current ID)
170039.38 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
170039.38 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170039.38 1 path {EV_PLAY_FINISHED} not found
170039.38 1 timer set 10 EV_TIMEOUT_HANGUP
170039.38 1 timer set 0 EV_TIMEOUT_GOTOMODULE
170039.38 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
170039.38 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
170039.38 1 path {EV_TIMEOUT_GOTOMODULE} not found
170039.38 1 next module is [CallForName] (idx=51)
170039.38 1 RunModule start [Play,[CallForName],51,,]
170039.38 1 tw DialogicEvent 129,TDX_PLAY,220000,0,0,,,
170039.38 1 event TDX_PLAY, iCode=129 state=6001
170039.38 1 LsModuleTransition : 129, [TDX_PLAY]
170039.38 1 timer clear bForceClear=False
170039.38 1 Play Module start
170039.38 1 state [CallForName] Playing
170039.38 1 tts deleted previous C:\Program Files\VoiceGuide\temp\tts_1_1.wav
170039.38 1 rv replace start: [<rate speed="-2">$RV[FirstName] $RV[LastName]. I am assembling a crew. Job is $RV[jobdesc].</rate>]
170039.38 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{Sally}[Last
ScriptEnd_Time]{8/18/2008 5:00:34 PM}[scriptEnd_Goto_Script]{c:\toa\callout\UGI_trial\ugi_am1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{8/18/2008 5:00:34 PM}[scriptStart_CalledFrom_Module]{UpdateTOA}[scriptsPath]{c:\toa\callout\UGI_trial\}[scriptPath]{c:\toa\callout\UGI_trial\}
170039.38 1 rv replace end: [<rate speed="-2">Sally Tan. I am assembling a crew. Job is Building Maint..</rate>]
170039.38 1 tts generate start[<rate speed="-2">Sally Tan. I am assembling a crew. Job is Building Maint..</rate>]
170039.38 1 tts generate wait
170039.47 1 tts generate finish
170039.47 1 state [CallForName] Playing (C:\toa\ugivoice\UGI_Callout_Voice\ThisIsACallFor3.wav, C:\Program Files\VoiceGuide\temp\tts_1_1.wav)
170039.47 1 timer clear bForceClear=False
170039.50 1 play start ok, lPlayId=225187
170046.89 1 tw PlayEnd 1 225187
170046.89 1 play end id=225187, (current ID)
170046.89 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
170046.89 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170046.89 1 path {EV_PLAY_FINISHED} not found
170046.89 1 timer set 10 EV_TIMEOUT_HANGUP
170046.89 1 timer set 0 EV_TIMEOUT_GOTOMODULE
170046.89 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
170046.89 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
170046.89 1 path {EV_TIMEOUT_GOTOMODULE} not found
170046.89 1 next module is [sayCurrentDateTime] (idx=50)
170046.89 1 RunModule start [say Numbers,[sayCurrentDateTime],50,,]
170046.89 1 tw DialogicEvent 129,TDX_PLAY,225187,0,0,,,
170046.89 1 event TDX_PLAY, iCode=129 state=6001
170046.89 1 LsModuleTransition : 129, [TDX_PLAY]
170046.89 1 timer clear bForceClear=False
170046.89 1 rv replace start: [$RV_STARTTIME]
170046.89 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[PhoneNumberCalled]{3231112}[TOAID]{100}[JOBID]{24}[FirstName]{Sally}[Last
170046.89 1 rv replace end: [8/18/2008 5:00:20 PM]
170046.89 1 state [sayCurrentDateTime] Say numbers: 8/18/2008 5:00:20 PM as Date & Time - SQL Long Date & Time
170046.89 1 fn PlaySoundStartNumbers [C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav],[],[8/18/2008 5:00:20 PM],Date & Time - SQL Long Date & Time
170046.89 1 svb script:[]
170115.33 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
170115.58 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
170115.58 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
170115.58 1 init atidle reinit : start
170115.58 1 init atidle reinit iConferenceOtherLegLid=-1
170115.58 1 init atidle reinit : reset all LineState variables
170115.58 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
170115.58 1 state Waiting for a call...
170117.77 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
170117.77 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
170117.77 1 setting iDialoutReadyToDialout = 1
170120.03 1 event callstate OFFERING 1 2,0,0
170120.03 1 script interpretor: VgMulti v6.0.3379
170120.03 1 fired OFFERING event to listeners
170120.03 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
170120.03 1 cid CallerID vars set (in 'offering' event) [,,]
170120.03 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
170120.03 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
170120.03 1 tw ring 1
170120.03 1 ring time since last ring event (sec): 0.00
170120.03 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
170120.03 1 should answer as number of rings reached
170120.03 1 rv clear all
170120.03 1 init LineState ResetAtStartOfNewCall.
170120.03 1 starting without answering the call (link pickup is not made)
170120.03 1 StartLoadedVgs at 8/18/2008 5:01:20 PM (VgMulti v6.0.3379)
170120.03 1 set LineState().iVgsIdx=1
170120.03 1 set sScriptToRunOnHangup=[C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs] in StartLoadedVgs
170120.03 1 init StartLoadedVgs_InitLineState start
170120.03 1 rv add [$RV_STARTTIME]{8/18/2008 5:01:20 PM}
170120.03 1 rv add [$RV_DEVICEID]{1}
170120.03 1 rv add [DlgcNetworkResource]{dxxxB1C1}
170120.03 1 rv add [DlgcVoiceResource]{dxxxB1C1}
170120.03 1 rv add [$RV_CIDNAME]{}
170120.03 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
170120.03 1 rvns add [scriptsPath]{C:\toa\callout\UGI_trial\}
170120.03 1 rvns add [scriptPath]{C:\toa\callout\UGI_trial\}
170120.03 1 rv add [$RV_CIDNUMBER]{}
170120.03 1 RunModule start [Play,[Play 1],17,,]
170120.03 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
170120.03 1 event TDX_CST, iCode=134 state=6001
170120.03 1 LsModuleTransition : 134, [TDX_CST]
170120.03 1 timer clear bForceClear=False
170120.03 1 Play Module start
170120.03 1 state [Play 1] Playing
170120.03 1 answering the call (,,,0)
170120.03 1 timer clear bForceClear=True
170120.66 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
170120.66 1 event TDX_SETHOOK, iCode=135 state=6001
170120.66 1 LsModuleTransition : 135, [TDX_SETHOOK]
170120.66 1 event callstate CONNECTED 1 256,0,0
170120.66 1 LineEvCallState_Connected hDevice=1 params=256,0,0
170120.66 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
170121.66 1 Inband detection not enabled
170121.66 1 RunModule start [Play,[Play 1],17,,]
170121.66 1 tw DialogicEvent 134,TDX_CST,537,0,0,DE_LCON,,
170121.66 1 event TDX_CST, iCode=134 state=6001
170121.66 1 LsModuleTransition : 134, [TDX_CST]
170121.66 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
170121.66 1 event FAX, iCode=134 state=6001
170121.66 1 LsModuleTransition : 134, [FAX]
170121.67 1 timer clear bForceClear=False
170121.67 1 Play Module start
170121.67 1 state [Play 1] Playing
170121.67 1 state [Play 1] Playing (C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav)
170121.69 1 play start ok, lPlayId=267390
170123.86 1 tw PlayEnd 1 267390
170123.86 1 play end id=267390, (current ID)
170123.86 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
170123.86 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170123.86 1 path {EV_PLAY_FINISHED} not found
170123.86 1 timer set 10 EV_TIMEOUT_HANGUP
170123.86 1 timer set 0 EV_TIMEOUT_GOTOMODULE
170123.86 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
170123.86 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
170123.86 1 path {EV_TIMEOUT_GOTOMODULE} not found
170123.86 1 next module is [FromUGI] (idx=1)
170123.86 1 RunModule start [Play,[FromUGI],1,,]
170123.86 1 tw DialogicEvent 129,TDX_PLAY,267390,0,0,,,
170123.86 1 event TDX_PLAY, iCode=129 state=6001
170123.86 1 LsModuleTransition : 129, [TDX_PLAY]
170123.86 1 timer clear bForceClear=False
170123.86 1 Play Module start
170123.86 1 state [FromUGI] Playing
170123.86 1 state [FromUGI] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
170123.89 1 play start ok, lPlayId=269578
170128.95 1 tw PlayEnd 1 269578
170128.95 1 play end id=269578, (current ID)
170128.95 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
170128.95 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170128.95 1 path {EV_PLAY_FINISHED} not found
170128.95 1 timer set 10 EV_TIMEOUT_HANGUP
170128.95 1 timer set 1 EV_TIMEOUT_GOTOMODULE
170128.95 1 tw DialogicEvent 129,TDX_PLAY,269578,0,0,,,
170128.95 1 event TDX_PLAY, iCode=129 state=1101
170128.95 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
170128.95 1 path {TDX_PLAY} not found
170129.97 1 timer fired EV_TIMEOUT_GOTOMODULE
170129.97 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
170129.97 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
170129.97 1 path {EV_TIMEOUT_GOTOMODULE} not found
170129.97 1 next module is [GetCall_Id] (idx=7)
170129.97 1 RunModule start [Get Numbers,[GetCall_Id],7,,]
170129.97 1 timer clear bForceClear=False
170129.97 1 state [GetCall_Id] Number Input
170129.97 1 state [GetCall_Id] Playing (C:\toa\ugivoice\UGI_Callout_Voice\EnterRequestID_2.wav)
170130.05 1 play start ok, lPlayId=275687
170142.42 1 tw DialogicEvent 134,TDX_CST,2176,0,0,DE_LCOF,,
170142.42 1 event DE_LCOF, iCode=134 state=1300
170142.42 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,DE_LCOF
170142.42 1 path {DE_LCOF} not found
170142.42 1 HangupCall start (Loop Current Off (non-xfer vgm))
170142.42 1 rv add [Hangup Time]{8/18/2008 5:01:42 PM}
170142.42 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
170142.42 1 HangupCall_Common hCall=1
170142.42 1 play PlayStop ok
170142.42 1 timer set 1 EV_TIMEOUT_DOLINEDROP
170142.42 1 fnHangupCall end
170142.42 1 tw PlayEnd 1 275687
170142.42 1 play end id=275687, (current ID)
170142.42 1 event EV_PLAY_FINISHED, iCode=8001 state=900
170142.42 1 LsAwaitingCalls EV_PLAY_FINISHED
170142.42 1 tw DialogicEvent 129,TDX_PLAY,275687,0,0,,,
170142.42 1 event TDX_PLAY, iCode=129 state=900
170142.42 1 LsAwaitingCalls EV_UNKNOWN_129
170142.73 1 tw DialogicEvent 134,TDX_CST,31,0,0,DE_LCON,,
170142.73 1 event TDX_CST, iCode=134 state=900
170142.73 1 LsAwaitingCalls EV_UNKNOWN_134
170143.44 1 timer fired EV_TIMEOUT_DOLINEDROP
170143.44 1 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
170143.44 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
170143.47 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
170143.47 1 event TDX_SETHOOK, iCode=135 state=900
170143.47 1 LsAwaitingCalls EV_UNKNOWN_135
170143.47 1 event callstate IDLE 1 1,0,0
170143.47 1 WorkingMode@Idle=
170143.47 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
170143.47 1 timer clear bForceClear=True
170143.47 1 rec RecSoundStop ok
170143.48 1 play PlayStop ok
170143.48 1 rv add [CallEndTime]{8/18/2008 5:01:43 PM}
170143.48 1 on-hangup script:[C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs]
170143.48 1 FindFullPathToScript_VgsOrVgp start [C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs]
170143.48 0 LoadedVgs_Find C:\toa\callout\UGI_trial\ugi_onfinish_1.vgs at idx=2
170143.48 1 setting .iVgmIdx_AfterHangupRun=18, .iVgsIdx_AfterHangupRun=2
171431.70 1 init atidle reinit : reset all LineState variables
171431.70 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171431.70 1 state Waiting for a call...
171433.89 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171433.89 1 setting iDialoutReadyToDialout = 1
171436.88 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
171436.88 1 cid CallerID vars set (in 'offering' event) [,,]
171436.88 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171436.88 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171436.88 1 tw ring 1
171436.88 1 ring time since last ring event (sec): 0.00
171436.88 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171436.88 1 should answer as number of rings reached
171436.88 1 rv clear all
171436.88 1 init LineState ResetAtStartOfNewCall.
171436.88 1 starting without answering the call (link pickup is not made)
171436.88 1 StartLoadedVgs at 8/18/2008 5:14:36 PM (VgMulti v6.0.3379)
171436.88 1 set LineState().iVgsIdx=6
171436.88 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
171436.88 1 init StartLoadedVgs_InitLineState start
171436.88 1 rv add [$RV_STARTTIME]{8/18/2008 5:14:36 PM}
171436.88 1 rv add [$RV_DEVICEID]{1}
171436.88 1 rv add [DlgcNetworkResource]{dxxxB1C1}
171436.88 1 rv add [DlgcVoiceResource]{dxxxB1C1}
171436.88 1 rv add [$RV_CIDNAME]{}
171436.88 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
171436.88 1 rvns add [scriptPath]{C:\toa\callout\UGI_trial\}
171436.88 1 rv add [$RV_CIDNUMBER]{}
171436.88 1 RunModule start [Play,[Play 1],62,,]
171436.88 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171436.88 1 event TDX_CST, iCode=134 state=6001
171436.88 1 LsModuleTransition : 134, [TDX_CST]
171436.88 1 timer clear bForceClear=False
171436.88 1 Play Module start
171436.88 1 state [Play 1] Playing
171436.88 1 answering the call (,,,0)
171436.88 1 timer clear bForceClear=True
171437.50 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171437.50 1 event TDX_SETHOOK, iCode=135 state=6001
171437.50 1 LsModuleTransition : 135, [TDX_SETHOOK]
171437.50 1 event callstate CONNECTED 1 256,0,0
171437.50 1 LineEvCallState_Connected hDevice=1 params=256,0,0
171437.50 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
171438.50 1 Inband detection not enabled
171438.50 1 RunModule start [Play,[Play 1],62,,]
171438.50 1 tw DialogicEvent 134,TDX_CST,608,0,0,DE_LCON,,
171438.50 1 event TDX_CST, iCode=134 state=6001
171438.50 1 LsModuleTransition : 134, [TDX_CST]
171438.50 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
171438.50 1 event FAX, iCode=134 state=6001
171438.50 1 LsModuleTransition : 134, [FAX]
171438.52 1 timer clear bForceClear=False
171438.52 1 Play Module start
171438.52 1 state [Play 1] Playing
171438.52 1 state [Play 1] Playing (C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav)
171438.53 1 play start ok, lPlayId=64234
171440.70 1 tw PlayEnd 1 64234
171440.70 1 play end id=64234, (current ID)
171440.70 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171440.70 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171440.70 1 path {EV_PLAY_FINISHED} not found
171440.70 1 timer set 10 EV_TIMEOUT_HANGUP
171440.70 1 timer set 0 EV_TIMEOUT_GOTOMODULE
171440.70 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171440.70 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171440.70 1 path {EV_TIMEOUT_GOTOMODULE} not found
171440.70 1 next module is [FromUGI] (idx=27)
171440.70 1 RunModule start [Play,[FromUGI],27,,]
171440.70 1 tw DialogicEvent 129,TDX_PLAY,64234,0,0,,,
171440.70 1 event TDX_PLAY, iCode=129 state=6001
171440.70 1 LsModuleTransition : 129, [TDX_PLAY]
171440.70 1 timer clear bForceClear=False
171440.70 1 Play Module start
171440.73 1 play start ok, lPlayId=66421
171445.80 1 tw PlayEnd 1 66421
171445.80 1 play end id=66421, (current ID)
171445.80 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171445.80 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171445.80 1 path {EV_PLAY_FINISHED} not found
171445.80 1 timer set 10 EV_TIMEOUT_HANGUP
171445.80 1 timer set 1 EV_TIMEOUT_GOTOMODULE
171445.80 1 tw DialogicEvent 129,TDX_PLAY,66421,0,0,,,
171445.80 1 event TDX_PLAY, iCode=129 state=1101
171445.80 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171445.80 1 path {TDX_PLAY} not found
171446.81 1 timer fired EV_TIMEOUT_GOTOMODULE
171446.81 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171446.81 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171446.81 1 path {EV_TIMEOUT_GOTOMODULE} not found
171446.81 1 next module is [GetCall_Id] (idx=52)
171446.81 1 RunModule start [Get Numbers,[GetCall_Id],52,,]
171446.81 1 timer clear bForceClear=False
171446.81 1 state [GetCall_Id] Number Input
171446.81 1 state [GetCall_Id] Playing (C:\toa\ugivoice\UGI_Callout_Voice\EnterRequestID_2.wav)
171446.89 1 play start ok, lPlayId=72531
171459.22 1 tw DialogicEvent 134,TDX_CST,2173,0,0,DE_LCOF,,
171459.22 1 event DE_LCOF, iCode=134 state=1300
171459.22 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,DE_LCOF
171459.22 1 path {DE_LCOF} not found
171459.22 1 HangupCall start (Loop Current Off (non-xfer vgm))
171459.22 1 rv add [Hangup Time]{8/18/2008 5:14:59 PM}
171459.23 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
171459.23 1 HangupCall_Common hCall=1
171459.23 1 play PlayStop ok
171459.23 1 timer set 1 EV_TIMEOUT_DOLINEDROP
171459.23 1 fnHangupCall end
171459.23 1 tw PlayEnd 1 72531
171459.23 1 play end id=72531, (current ID)
171459.23 1 event EV_PLAY_FINISHED, iCode=8001 state=900
171459.23 1 LsAwaitingCalls EV_PLAY_FINISHED
171459.23 1 tw DialogicEvent 129,TDX_PLAY,72531,0,0,,,
171459.23 1 event TDX_PLAY, iCode=129 state=900
171459.23 1 LsAwaitingCalls EV_UNKNOWN_129
171459.55 1 tw DialogicEvent 134,TDX_CST,32,0,0,DE_LCON,,
171459.55 1 event TDX_CST, iCode=134 state=900
171459.55 1 LsAwaitingCalls EV_UNKNOWN_134
171500.23 1 timer fired EV_TIMEOUT_DOLINEDROP
171500.23 1 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
171500.23 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171500.27 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171500.27 1 event TDX_SETHOOK, iCode=135 state=900
171500.27 1 LsAwaitingCalls EV_UNKNOWN_135
171500.27 1 event callstate IDLE 1 1,0,0
171500.27 1 WorkingMode@Idle=
171500.27 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
171500.27 1 timer clear bForceClear=True
171500.27 1 rec RecSoundStop ok
171500.28 1 play PlayStop ok
171500.28 1 rv add [CallEndTime]{8/18/2008 5:15:00 PM}
171500.28 1 on-hangup script:[]
171500.28 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
171500.56 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
171500.56 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
171500.56 1 init atidle reinit : start
171500.56 1 init atidle reinit iConferenceOtherLegLid=-1
171500.56 1 init atidle reinit : reset all LineState variables
171500.56 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171500.56 1 state Waiting for a call...
171502.53 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
171502.53 1 event FAX, iCode=134 state=900
171502.53 1 LsAwaitingCalls EV_UNKNOWN_134
171502.53 1 event TDX_CST, iCode=134 state=900
171502.75 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171502.75 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171502.75 1 setting iDialoutReadyToDialout = 1
171503.16 1 event callstate OFFERING 1 2,0,0
171503.16 1 script interpretor: VgMulti v6.0.3379
171503.16 1 fired OFFERING event to listeners
171503.16 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
171503.17 1 cid CallerID vars set (in 'offering' event) [,,]
171503.17 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171503.17 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171503.17 1 tw ring 1
171503.17 1 ring time since last ring event (sec): 0.00
171503.17 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171503.17 1 should answer as number of rings reached
171503.17 1 rv clear all
171503.17 1 init LineState ResetAtStartOfNewCall.
171503.17 1 starting without answering the call (link pickup is not made)
171503.17 1 StartLoadedVgs at 8/18/2008 5:15:03 PM (VgMulti v6.0.3379)
171503.17 1 set LineState().iVgsIdx=6
171503.17 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
171503.17 1 init StartLoadedVgs_InitLineState start
171503.17 1 rv add [$RV_STARTTIME]{8/18/2008 5:15:03 PM}
171503.17 1 rv add [$RV_DEVICEID]{1}
171503.17 1 rv add [DlgcNetworkResource]{dxxxB1C1}
171503.17 1 rv add [DlgcVoiceResource]{dxxxB1C1}
171503.17 1 rv add [$RV_CIDNAME]{}
171503.17 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
171503.17 1 rvns add [scriptsPath]{C:\toa\callout\UGI_trial\}
171503.17 1 rvns add [scriptPath]{C:\toa\callout\UGI_trial\}
171503.17 1 rv add [$RV_CIDNUMBER]{}
171503.17 1 RunModule start [Play,[Play 1],62,,]
171503.17 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171503.17 1 event TDX_CST, iCode=134 state=6001
171503.17 1 LsModuleTransition : 134, [TDX_CST]
171503.17 1 timer clear bForceClear=False
171503.17 1 Play Module start
171503.17 1 state [Play 1] Playing
171503.17 1 answering the call (,,,0)
171503.17 1 timer clear bForceClear=True
171503.80 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171503.80 1 event TDX_SETHOOK, iCode=135 state=6001
171503.80 1 LsModuleTransition : 135, [TDX_SETHOOK]
171503.80 1 event callstate CONNECTED 1 256,0,0
171503.80 1 LineEvCallState_Connected hDevice=1 params=256,0,0
171503.80 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
171503.80 1 Inband detection not enabled
171503.80 1 RunModule start [Play,[Play 1],62,,]
171503.80 1 timer clear bForceClear=False
171503.80 1 Play Module start
171503.80 1 state [Play 1] Playing
171503.80 1 state [Play 1] Playing (C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav)
171503.81 1 play start ok, lPlayId=89515
171503.81 1 tw DialogicEvent 134,TDX_CST,352,0,0,DE_LCON,,
171503.81 1 event TDX_CST, iCode=134 state=1100
171503.81 1 LsPlayMsg EV_UNKNOWN_134,TDX_CST
171503.81 1 path {TDX_CST} not found
171505.98 1 tw PlayEnd 1 89515
171505.98 1 play end id=89515, (current ID)
171505.98 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171506.00 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171506.00 1 path {EV_PLAY_FINISHED} not found
171506.00 1 timer set 10 EV_TIMEOUT_HANGUP
171506.00 1 timer set 0 EV_TIMEOUT_GOTOMODULE
171506.00 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171506.00 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171506.00 1 path {EV_TIMEOUT_GOTOMODULE} not found
171506.00 1 next module is [FromUGI] (idx=27)
171506.00 1 RunModule start [Play,[FromUGI],27,,]
171506.00 1 tw DialogicEvent 129,TDX_PLAY,89515,0,0,,,
171506.00 1 event TDX_PLAY, iCode=129 state=6001
171506.00 1 LsModuleTransition : 129, [TDX_PLAY]
171506.00 1 timer clear bForceClear=False
171506.00 1 Play Module start
171506.00 1 state [FromUGI] Playing
171506.00 1 state [FromUGI] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
171506.02 1 play start ok, lPlayId=91718
171511.08 1 tw PlayEnd 1 91718
171511.08 1 play end id=91718, (current ID)
171511.08 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171511.08 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171511.08 1 path {EV_PLAY_FINISHED} not found
171511.08 1 timer set 10 EV_TIMEOUT_HANGUP
171511.08 1 timer set 1 EV_TIMEOUT_GOTOMODULE
171511.08 1 tw DialogicEvent 129,TDX_PLAY,91718,0,0,,,
171511.08 1 event TDX_PLAY, iCode=129 state=1101
171511.08 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171511.08 1 path {TDX_PLAY} not found
171512.16 1 timer fired EV_TIMEOUT_GOTOMODULE
171512.16 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171512.16 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171512.16 1 path {EV_TIMEOUT_GOTOMODULE} not found
171512.16 1 next module is [GetCall_Id] (idx=52)
171512.16 1 RunModule start [Get Numbers,[GetCall_Id],52,,]
171512.16 1 timer clear bForceClear=False
171512.16 1 state [GetCall_Id] Number Input
171512.16 1 state [GetCall_Id] Playing (C:\toa\ugivoice\UGI_Callout_Voice\EnterRequestID_2.wav)
171512.23 1 play start ok, lPlayId=97875
171524.42 1 tw DialogicEvent 134,TDX_CST,2063,0,0,DE_LCOF,,
171524.42 1 event DE_LCOF, iCode=134 state=1300
171524.42 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,DE_LCOF
171524.42 1 path {DE_LCOF} not found
171524.42 1 HangupCall start (Loop Current Off (non-xfer vgm))
171524.42 1 rv add [Hangup Time]{8/18/2008 5:15:24 PM}
171524.42 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
171524.42 1 HangupCall_Common hCall=1
171524.44 1 play PlayStop ok
171524.44 1 timer set 1 EV_TIMEOUT_DOLINEDROP
171524.44 1 fnHangupCall end
171524.44 1 tw PlayEnd 1 97875
171524.44 1 play end id=97875, (current ID)
171524.44 1 event EV_PLAY_FINISHED, iCode=8001 state=900
171524.44 1 LsAwaitingCalls EV_PLAY_FINISHED
171524.44 1 tw DialogicEvent 129,TDX_PLAY,97875,0,0,,,
171524.44 1 event TDX_PLAY, iCode=129 state=900
171524.44 1 LsAwaitingCalls EV_UNKNOWN_129
171524.73 1 tw DialogicEvent 134,TDX_CST,31,0,0,DE_LCON,,
171524.73 1 event TDX_CST, iCode=134 state=900
171524.73 1 LsAwaitingCalls EV_UNKNOWN_134
171525.47 1 timer fired EV_TIMEOUT_DOLINEDROP
171525.47 1 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
171525.47 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171525.52 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171525.52 1 event TDX_SETHOOK, iCode=135 state=900
171525.52 1 LsAwaitingCalls EV_UNKNOWN_135
171525.52 1 event callstate IDLE 1 1,0,0
171525.52 1 WorkingMode@Idle=
171525.52 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
171525.52 1 timer clear bForceClear=True
171525.52 1 rec RecSoundStop ok
171525.52 1 play PlayStop ok
171525.52 1 rv add [CallEndTime]{8/18/2008 5:15:25 PM}
171525.52 1 on-hangup script:[]
171525.52 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
171525.80 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
171525.80 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
171525.80 1 init atidle reinit : start
171525.80 1 init atidle reinit iConferenceOtherLegLid=-1
171525.80 1 init atidle reinit : reset all LineState variables
171525.80 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171525.80 1 state Waiting for a call...
171527.98 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171527.98 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171527.98 1 setting iDialoutReadyToDialout = 1
171707.20 0 sys cleanup Start
171707.20 0 sys cleanup End
171747.41 1 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
171747.41 1 event DISCONNECT_TAPI2, iCode=134 state=900
171747.41 1 LsAwaitingCalls EV_UNKNOWN_134
171747.41 1 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
171747.41 1 already IDLE. HangupCall ignored.
171747.41 1 init atidle reinit : start
171747.41 1 init atidle reinit iConferenceOtherLegLid=-1
171747.41 1 init atidle reinit : reset all LineState variables
171747.41 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171747.41 1 state Waiting for a call...
171747.41 1 event TDX_CST, iCode=134 state=900
171749.52 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171749.52 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171749.52 1 setting iDialoutReadyToDialout = 1
171757.05 1 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
171757.05 1 event DISCONNECT_TAPI2, iCode=134 state=900
171757.05 1 LsAwaitingCalls EV_UNKNOWN_134
171757.05 1 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
171757.05 1 already IDLE. HangupCall ignored.
171757.05 1 init atidle reinit : start
171757.05 1 init atidle reinit iConferenceOtherLegLid=-1
171757.05 1 init atidle reinit : reset all LineState variables
171757.05 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171757.05 1 state Waiting for a call...
171757.05 1 event TDX_CST, iCode=134 state=900
171759.14 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171759.14 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171759.14 1 setting iDialoutReadyToDialout = 1
171856.17 1 event callstate OFFERING 1 2,0,0
171856.17 1 script interpretor: VgMulti v6.0.3379
171856.17 1 fired OFFERING event to listeners
171856.17 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
171856.17 1 cid CallerID vars set (in 'offering' event) [,,]
171856.17 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171856.17 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171856.17 1 tw ring 1
171856.17 1 ring time since last ring event (sec): 0.00
171856.17 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171856.17 1 should answer as number of rings reached
171856.17 1 rv clear all
171856.17 1 init LineState ResetAtStartOfNewCall.
171856.17 1 starting without answering the call (link pickup is not made)
171856.17 1 StartLoadedVgs at 8/18/2008 5:18:56 PM (VgMulti v6.0.3379)
171856.17 1 set LineState().iVgsIdx=6
171856.17 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
171856.17 1 init StartLoadedVgs_InitLineState start
171856.17 1 rv add [$RV_STARTTIME]{8/18/2008 5:18:56 PM}
171856.17 1 rv add [$RV_DEVICEID]{1}
171856.17 1 rv add [DlgcNetworkResource]{dxxxB1C1}
171856.17 1 rv add [DlgcVoiceResource]{dxxxB1C1}
171856.17 1 rv add [$RV_CIDNAME]{}
171856.17 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
171856.17 1 rvns add [scriptsPath]{C:\toa\callout\UGI_trial\}
171856.17 1 rvns add [scriptPath]{C:\toa\callout\UGI_trial\}
171856.17 1 rv add [$RV_CIDNUMBER]{}
171856.17 1 RunModule start [Play,[Play 1],62,,]
171856.17 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171856.17 1 event TDX_CST, iCode=134 state=6001
171856.17 1 LsModuleTransition : 134, [TDX_CST]
171856.17 1 timer clear bForceClear=False
171856.17 1 Play Module start
171856.17 1 state [Play 1] Playing
171856.17 1 answering the call (,,,0)
171856.17 1 timer clear bForceClear=True
171856.80 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171856.80 1 event TDX_SETHOOK, iCode=135 state=6001
171856.80 1 LsModuleTransition : 135, [TDX_SETHOOK]
171856.80 1 event callstate CONNECTED 1 256,0,0
171856.80 1 LineEvCallState_Connected hDevice=1 params=256,0,0
171856.80 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
171857.80 1 Inband detection not enabled
171857.80 1 RunModule start [Play,[Play 1],62,,]
171857.80 1 tw DialogicEvent 134,TDX_CST,21129,0,0,DE_LCON,,
171857.80 1 event TDX_CST, iCode=134 state=6001
171857.80 1 LsModuleTransition : 134, [TDX_CST]
171857.80 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
171857.80 1 event FAX, iCode=134 state=6001
171857.80 1 LsModuleTransition : 134, [FAX]
171857.80 1 timer clear bForceClear=False
171857.80 1 Play Module start
171857.80 1 state [Play 1] Playing
171857.80 1 state [Play 1] Playing (C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav)
171857.81 1 play start ok, lPlayId=323515
171900.00 1 tw PlayEnd 1 323515
171900.00 1 play end id=323515, (current ID)
171900.00 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171900.00 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171900.00 1 path {EV_PLAY_FINISHED} not found
171900.00 1 timer set 10 EV_TIMEOUT_HANGUP
171900.00 1 timer set 0 EV_TIMEOUT_GOTOMODULE
171900.00 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171900.00 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171900.00 1 path {EV_TIMEOUT_GOTOMODULE} not found
171900.00 1 next module is [FromUGI] (idx=27)
171900.00 1 RunModule start [Play,[FromUGI],27,,]
171900.00 1 tw DialogicEvent 129,TDX_PLAY,323515,0,0,,,
171900.00 1 event TDX_PLAY, iCode=129 state=6001
171900.00 1 LsModuleTransition : 129, [TDX_PLAY]
171900.00 1 timer clear bForceClear=False
171900.00 1 Play Module start
171900.00 1 state [FromUGI] Playing
171900.00 1 state [FromUGI] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
171900.03 1 play start ok, lPlayId=325718
171905.09 1 tw PlayEnd 1 325718
171905.09 1 play end id=325718, (current ID)
171905.09 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171905.09 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171905.09 1 path {EV_PLAY_FINISHED} not found
171905.09 1 timer set 10 EV_TIMEOUT_HANGUP
171905.09 1 timer set 1 EV_TIMEOUT_GOTOMODULE
171905.09 1 tw DialogicEvent 129,TDX_PLAY,325718,0,0,,,
171905.09 1 event TDX_PLAY, iCode=129 state=1101
171905.09 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171905.09 1 path {TDX_PLAY} not found
171906.11 1 timer fired EV_TIMEOUT_GOTOMODULE
171906.11 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171906.11 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171906.11 1 path {EV_TIMEOUT_GOTOMODULE} not found
171906.11 1 next module is [GetCall_Id] (idx=52)
171906.11 1 RunModule start [Get Numbers,[GetCall_Id],52,,]
171906.11 1 timer clear bForceClear=False
171906.11 1 state [GetCall_Id] Number Input
171906.11 1 state [GetCall_Id] Playing (C:\toa\ugivoice\UGI_Callout_Voice\EnterRequestID_2.wav)
171906.19 1 play start ok, lPlayId=331828
171918.52 1 tw DialogicEvent 134,TDX_CST,2173,0,0,DE_LCOF,,
171918.52 1 event DE_LCOF, iCode=134 state=1300
171918.52 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,DE_LCOF
171918.52 1 path {DE_LCOF} not found
171918.52 1 HangupCall start (Loop Current Off (non-xfer vgm))
171918.52 1 rv add [Hangup Time]{8/18/2008 5:19:18 PM}
171918.52 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
171918.52 1 HangupCall_Common hCall=1
171918.55 1 play PlayStop ok
171918.55 1 timer set 1 EV_TIMEOUT_DOLINEDROP
171918.55 1 fnHangupCall end
171918.55 1 tw PlayEnd 1 331828
171918.55 1 play end id=331828, (current ID)
171918.55 1 event EV_PLAY_FINISHED, iCode=8001 state=900
171918.55 1 LsAwaitingCalls EV_PLAY_FINISHED
171918.55 1 tw DialogicEvent 129,TDX_PLAY,331828,0,0,,,
171918.55 1 event TDX_PLAY, iCode=129 state=900
171918.55 1 LsAwaitingCalls EV_UNKNOWN_129
171918.83 1 tw DialogicEvent 134,TDX_CST,30,0,0,DE_LCON,,
171918.83 1 event TDX_CST, iCode=134 state=900
171918.83 1 LsAwaitingCalls EV_UNKNOWN_134
171919.53 1 timer fired EV_TIMEOUT_DOLINEDROP
171919.53 1 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
171919.53 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171919.56 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171919.56 1 event TDX_SETHOOK, iCode=135 state=900
171919.56 1 LsAwaitingCalls EV_UNKNOWN_135
171919.56 1 event callstate IDLE 1 1,0,0
171919.56 1 WorkingMode@Idle=
171919.56 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
171919.56 1 timer clear bForceClear=True
171919.56 1 rec RecSoundStop ok
171919.58 1 play PlayStop ok
171919.58 1 rv add [CallEndTime]{8/18/2008 5:19:19 PM}
171919.58 1 on-hangup script:[]
171919.58 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
171919.86 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
171919.86 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
171919.86 1 init atidle reinit : start
171919.86 1 init atidle reinit iConferenceOtherLegLid=-1
171919.86 1 init atidle reinit : reset all LineState variables
171919.86 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171919.86 1 state Waiting for a call...
171921.84 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
171921.84 1 event FAX, iCode=134 state=900
171921.84 1 LsAwaitingCalls EV_UNKNOWN_134
171921.84 1 event TDX_CST, iCode=134 state=900
171922.05 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171922.05 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171922.05 1 setting iDialoutReadyToDialout = 1
171922.47 1 event callstate OFFERING 1 2,0,0
171922.47 1 script interpretor: VgMulti v6.0.3379
171922.47 1 fired OFFERING event to listeners
171922.47 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
171922.47 1 cid CallerID vars set (in 'offering' event) [,,]
171922.47 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171922.47 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171922.47 1 tw ring 1
171922.47 1 ring time since last ring event (sec): 0.00
171922.47 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171922.47 1 should answer as number of rings reached
171922.47 1 rv clear all
171922.47 1 init LineState ResetAtStartOfNewCall.
171922.47 1 starting without answering the call (link pickup is not made)
171922.47 1 StartLoadedVgs at 8/18/2008 5:19:22 PM (VgMulti v6.0.3379)
171922.47 1 set LineState().iVgsIdx=6
171922.47 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
171922.47 1 init StartLoadedVgs_InitLineState start
171922.47 1 rv add [$RV_STARTTIME]{8/18/2008 5:19:22 PM}
171922.47 1 rv add [$RV_DEVICEID]{1}
171922.47 1 rv add [DlgcNetworkResource]{dxxxB1C1}
171922.47 1 rv add [DlgcVoiceResource]{dxxxB1C1}
171922.47 1 rv add [$RV_CIDNAME]{}
171922.47 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
171922.47 1 rvns add [scriptsPath]{C:\toa\callout\UGI_trial\}
171922.47 1 rvns add [scriptPath]{C:\toa\callout\UGI_trial\}
171922.47 1 rv add [$RV_CIDNUMBER]{}
171922.47 1 RunModule start [Play,[Play 1],62,,]
171922.47 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171922.47 1 event TDX_CST, iCode=134 state=6001
171922.47 1 LsModuleTransition : 134, [TDX_CST]
171922.47 1 timer clear bForceClear=False
171922.47 1 Play Module start
171922.47 1 state [Play 1] Playing
171922.47 1 answering the call (,,,0)
171922.47 1 timer clear bForceClear=True
171923.09 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171923.09 1 event TDX_SETHOOK, iCode=135 state=6001
171923.09 1 LsModuleTransition : 135, [TDX_SETHOOK]
171923.09 1 event callstate CONNECTED 1 256,0,0
171923.09 1 LineEvCallState_Connected hDevice=1 params=256,0,0
171923.09 1 WorkingModes tapi= script=BeforeAnswerRun LineState().iState=6001
171923.09 1 Inband detection not enabled
171923.09 1 RunModule start [Play,[Play 1],62,,]
171923.09 1 tw DialogicEvent 134,TDX_CST,352,0,0,DE_LCON,,
171923.09 1 event TDX_CST, iCode=134 state=6001
171923.09 1 LsModuleTransition : 134, [TDX_CST]
171923.09 1 timer clear bForceClear=False
171923.09 1 Play Module start
171923.09 1 state [Play 1] Playing
171923.09 1 state [Play 1] Playing (C:\toa\ugivoice\UGI_Callout_Voice\TimeIsNow3.wav)
171923.11 1 play start ok, lPlayId=348812
171925.30 1 tw PlayEnd 1 348812
171925.30 1 play end id=348812, (current ID)
171925.30 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171925.30 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171925.30 1 path {EV_PLAY_FINISHED} not found
171925.30 1 timer set 10 EV_TIMEOUT_HANGUP
171925.30 1 timer set 0 EV_TIMEOUT_GOTOMODULE
171925.30 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171925.30 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171925.30 1 path {EV_TIMEOUT_GOTOMODULE} not found
171925.30 1 next module is [FromUGI] (idx=27)
171925.30 1 RunModule start [Play,[FromUGI],27,,]
171925.30 1 tw DialogicEvent 129,TDX_PLAY,348812,0,0,,,
171925.30 1 event TDX_PLAY, iCode=129 state=6001
171925.30 1 LsModuleTransition : 129, [TDX_PLAY]
171925.30 1 timer clear bForceClear=False
171925.30 1 Play Module start
171925.30 1 state [FromUGI] Playing
171925.30 1 state [FromUGI] Playing (C:\toa\ugivoice\UGI_Callout_Voice\16511521.wav)
171925.31 1 play start ok, lPlayId=351015
171930.39 1 tw PlayEnd 1 351015
171930.39 1 play end id=351015, (current ID)
171930.39 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
171930.39 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171930.39 1 path {EV_PLAY_FINISHED} not found
171930.39 1 timer set 10 EV_TIMEOUT_HANGUP
171930.39 1 timer set 1 EV_TIMEOUT_GOTOMODULE
171930.39 1 tw DialogicEvent 129,TDX_PLAY,351015,0,0,,,
171930.39 1 event TDX_PLAY, iCode=129 state=1101
171930.39 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171930.39 1 path {TDX_PLAY} not found
171931.45 1 timer fired EV_TIMEOUT_GOTOMODULE
171931.45 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
171931.45 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171931.45 1 path {EV_TIMEOUT_GOTOMODULE} not found
171931.45 1 next module is [GetCall_Id] (idx=52)
171931.45 1 RunModule start [Get Numbers,[GetCall_Id],52,,]
171931.45 1 timer clear bForceClear=False
171931.45 1 state [GetCall_Id] Number Input
171931.45 1 state [GetCall_Id] Playing (C:\toa\ugivoice\UGI_Callout_Voice\EnterRequestID_2.wav)
171931.53 1 play start ok, lPlayId=357171
171943.81 1 tw DialogicEvent 134,TDX_CST,2072,0,0,DE_LCOF,,
171943.81 1 event DE_LCOF, iCode=134 state=1300
171943.81 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,DE_LCOF
171943.81 1 path {DE_LCOF} not found
171943.81 1 HangupCall start (Loop Current Off (non-xfer vgm))
171943.81 1 rv add [Hangup Time]{8/18/2008 5:19:43 PM}
171943.81 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
171943.81 1 HangupCall_Common hCall=1
171943.83 1 play PlayStop ok
171943.83 1 timer set 1 EV_TIMEOUT_DOLINEDROP
171943.83 1 fnHangupCall end
171943.83 1 tw PlayEnd 1 357171
171943.83 1 play end id=357171, (current ID)
171943.83 1 event EV_PLAY_FINISHED, iCode=8001 state=900
171943.83 1 LsAwaitingCalls EV_PLAY_FINISHED
171943.83 1 tw DialogicEvent 129,TDX_PLAY,357171,0,0,,,
171943.83 1 event TDX_PLAY, iCode=129 state=900
171943.84 1 LsAwaitingCalls EV_UNKNOWN_129
171944.14 1 tw DialogicEvent 134,TDX_CST,32,0,0,DE_LCON,,
171944.14 1 event TDX_CST, iCode=134 state=900
171944.14 1 LsAwaitingCalls EV_UNKNOWN_134
171944.88 1 timer fired EV_TIMEOUT_DOLINEDROP
171944.88 1 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
171944.88 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171944.91 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171944.91 1 event TDX_SETHOOK, iCode=135 state=900
171944.91 1 LsAwaitingCalls EV_UNKNOWN_135
171944.91 1 event callstate IDLE 1 1,0,0
171944.91 1 WorkingMode@Idle=
171944.91 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
171944.91 1 timer clear bForceClear=True
171944.92 1 rec RecSoundStop ok
171944.92 1 play PlayStop ok
171944.92 1 rv add [CallEndTime]{8/18/2008 5:19:44 PM}
171944.92 1 on-hangup script:[]
171944.92 1 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
171945.20 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
171945.20 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
171945.20 1 init atidle reinit : start
171945.20 1 init atidle reinit iConferenceOtherLegLid=-1
171945.20 1 init atidle reinit : reset all LineState variables
171945.20 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171945.20 1 state Waiting for a call...
171947.39 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
171947.39 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
171947.39 1 setting iDialoutReadyToDialout = 1
