Problems With String
Hi, we’ve been experiencing some difficulties with the VoiceGuide v6.0.3386.
Following the instructions on the VoiceGuide help, it says that you can use the function ‘mid’ on the Evaluate Expression. However, as we try to use it, it does nothing at all. It leaves the expression, and reads it as ‘mid(exp,0,1)’. Also, when I tried to use it on the VBScript, it gives a compilation error.
Best Regards,
Could you please post a copy of VoiceGuide's Trace Logs which capture the problem, this will allow us to see what happened.
Plesae include both cases of trying to use mid in an Evaluate Expression module and in a VBScript module.
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=10
ktTts=0
