If Statement In Vb Script
Can you/how do you do the following using a VBscript in VoiceGuide to do the following,
A user keys in a 4 digit number
If number entered is between 1000 and 1999 goto module x,
If number entered is between 2000 and 2999 goto module y,
On going to the module will vb script terminate?
What syntax do you use for the goto line?
How do you define the success path? if 1003 entered then success path module x followed, if 2003 entered then success path module y followed, can you define multiple success paths in the paths tab of the module definition?
Thanks in advance
Say the Get Numbers module in which the caller enters the 4 digit number is called GetSomeCode
The VBScript can be done something like this:
if $RV[GetSomeCode] >= 1000 and $RV[GetSomeCode] <= 1999 then
vg.Script_Goto $RV_LINEID, "", "Module1000", ""
end if
if $RV[GetSomeCode] >= 2000 and $RV[GetSomeCode] <= 2999 then
vg.Script_Goto $RV_LINEID, "", "Module2000", ""
end if
set vg = Nothing
The VBScript will complete normally, but VoiceGuide will start executing next module immediately.
For specific entries use paths like these in the GetSomeCode module:
on {1003} goto [x]
on {2003} goto [y]
Please post if you have any further questions.
Thank you for the reply.
The VBS module has three tabs
Run VBScript Tab
Play Tab
Paths Tab
The goto statements in the vbscript will cause the script to go to the appropriate module, but what paths do I need to define in the Paths Tab or do I need to define any as the goto statements will take care of this?
The Script_Goto statement sends an instruction direct to VoiceGuide to goto another module. Nothing extra needs to be defined in Paths tab or anywhere else to make the Script_Goto command to work.
I am having some trouble getting my if statement to work, it works OK outside of Voiceguide,
I have attached a log file for you to look at.
ifstatement.txt
Please attach the VoiceGuide script itself.
You can use the Admin_TraceLogAdd COM command to trace the VBScript execution. This will let you debug how any VBScript progresses as Admin_TraceLogAdd adds log entries to vgEngine file.
The VBScript in your VBScript modules is quite long. It's best to start of with a small subset of code and add to it and see at which stage the problem occurs. Using Admin_TraceLogAdd would also help to pinpoint the line on which the error occurs.
I have done as you have suggested reduced the size of my VBScript but I am still having problems, I have added trace logs to the script, when I run the script
I don't even get to see these in the log file. :wub:
I have attached a log file and a script with the VBScript included, any pointer in the right direction will be much appreciated. :rolleyes:
280708ifprob.txt
ifscript.vgs
Try changing the VBScript in the module [Test Parent Code] to something basic like:
Set vg = CreateObject("vgServices.CommandLink")
vg.Admin_TraceLogAdd 0, 0, "**** vgServices.CommandLink completed"
Set vg=Nothing
And then slowly add to that.
Also, you are trying to use a Excel spreadsheet as a database - scanning though spreadsheet cells to find a match.
Suggest you just switch to using a database, Excel is not the right tool for database lookup type operations.
I have done as you have suggested, I have written another script which tests the input from a user.
I add the admin trace logs as suggested, when I view the log files I can see the admin trace logs until I insert the if statement, then I can't see any comlg lines in the log file.
I have changed the vg.Script goto to statement from
vg.Script_Goto $RV_LINEID,"","module name", ""
to
vg.Script_Goto $RV_LINEID,"module name"
but this does not make any difference.
I have attached the log files for a few runs, first log file you can see the comlg lines, and also the vgs script that I am trying to test.
290708ifprob.txt
ifproblem.vgs
If the problem occurs when you add the "IF" statement then maybe you could try this:
If (($RV[GetSomeCode] >= 1000) And ($RV[GetSomeCode] <= 1999)) Then
end if
If (($RV[GetSomeCode] >= 2000) And ($RV[GetSomeCode] <= 2999)) Then
end if
or this:
If ($RV[GetSomeCode] >= 1000) Then
If ($RV[GetSomeCode] <= 1999) Then
end if
end if
If ($RV[GetSomeCode] >= 2000) Then
If ($RV[GetSomeCode] <= 2999) Then
end if
end if
To debug the VBScripts you should look at the VBScript file that VoiceGuide creates from the "Run VBScript" module. The trace file will show you the file to look at, eg:
215519.187 9 1 state [Test Parent Code] type: VB Script, iRunWait=1
215519.187 9 1 rv replace start (strlen>500)
215519.203 9 1 script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs
Try double clicking on that file (C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs) from above trace and if there is a problems with it then you should see the error message box appear telling you on which line the problem is occurring. You can then debug the VBScript and see what changes are necessary to make it work.
The vbs_1_1.vbs file is just the script from the "Run VBScript" module with all of the $RVs replaced by their actual values.
Found the problem, no space in "endif", when space inserted "end if" worked fine
Thanks for the help
