Hardware /features Issues.
I need to build a call center.
In my system I need a 4 incoming lines and 1 to 3 telephone handsets , what kind of hardware do I need , to connect the incoming lines and the telephone handsets? Do I need a PBX for any case?
I need the operator(human) to see the information about the customer, So how can I transfer the information to the operator desktop?
I need to recognize the customer that follow-up his calls to the call center. In what Ways can I do this?
I can not use the caller id , because the caller id is the phone number of the customer who called to my customer.
I thought about giving each customer a PIN number, when he does a follow-up to the call center, he add the PIN number to the phone number (like extension), using this number I can recognize the customer. For example:
My line phone number is 100.
Customer pin number 33.
The customer follow-up to the number 100#33.
using PIN 33 I can recognize the customer.
Can it be implemented?
If yes , How many PIN numbers(extensions) can the system support?
Thanks,
beginner.
Yes, you will need a PBX.
You can use VG Script or Run Program module to pop up information on the human operator's PC..
Yes.
Unlimited - you can store the PINs in a database and use the DB Query module to retrieve information about the customer based on PIN...
