Vbscript Problem
Hello,
I hope someone can help me, I am new to Voiceguide and VB scripting I am trying to run a script that does the following
A user Inputs a 5 digit or more code, program looks up an excel spreadsheet, if Input is 5
digits it looks up column 1, if more than 5 looks up colum 2. If empty cell encountered it's a fail, if number found success.
Later I want to ammend program so if number found a value stored in column 3 will be returned to program.
I have attached the program for you to look at.
Thanks in advance
Dim xlApp, xlBook, xlSht
Dim filename, value1, value2
filename = "C:\Test.xls"
Set xlApp = CreateObject("Excel.Application")
Set vg = CreateObject("vgservices.commandlink")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.ActiveSheet
vg.Admin_TraceLogAdd 0, 0, "This Trace was printed from an external VB Script"
Set vg=Nothing
strValueEnteredByCaller = $RVSecurity Code
if len(strValueEnteredByCaller) = 5 then
iColumn = 1
else
iColumn = 2
end if
'scan through all entries until match found or a blank cell is reached
i = 1
while xlSht.Cells(i, iColumn) <> strValueEnteredByCaller and xlSht.Cells(i, iColumn) <> ""
i = i + 1
wend
if xlSht.Cells(i, iColumn) = "" then
vg.Run_ResultReturn $RV_LINEID, "fail"
Set vg=Nothing
else
Set vg=Nothing
end if
xlBook.Close False
xlApp.Quit
'always deallocate after use...
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
Set vg=Nothing
What is the actual problem with the script?
It's best to add more vg.Admin_TraceLogAdd calls in the script. This way you will be able to trace how the script is executing and narrow down any problem areas. The Admin_TraceLogAdd function places log entries in the vgEngine log file.
vgEngine.txt
When I run the script entering a correct code it takes the fail path, When I look at the Line Status Monitor when my VGscriptit enters the VBScript module - iRunwait =1 is displayed for 40 seconds (Excel file only contains 2 cells in the column I'm checking) then it takes the fail path.
I have attached the VG engine file for you to look at.
vgEngine.txt
Not sure what is happening as you did not place sufficient tracing in the VB Script to let us see what is going on.
Also you have are seeing three CreateObject("vgServices.CommandLink") entries in script. You should only activate the "vgServices.CommandLink" object once per script. no need ot do this multiple times.
Try modifying the script as per below. It will better show what is happening in the script, and where the delays are.
Set vg = CreateObject("vgServices.CommandLink")
vg.Admin_TraceLogAdd 0, 0, "**** calling CreateObject Excel.Application"
vg.Admin_TraceLogAdd 0, 0, "**** calling WorkBooks.Open"
vg.Admin_TraceLogAdd 0, 0, "**** calling xlApp.ActiveSheet"
vg.Admin_TraceLogAdd 0, 0, "**** calling len(strValueEnteredByCaller)"
strValueEnteredByCaller = "$RV[security Code]"
iColumn = 1
else
iColumn = 2
end if
vg.Admin_TraceLogAdd 0, 0, "**** scaning through all entries until match found or a blank cell is reached "
i = 1
i = i + 1
wend
else
end if
vg.Admin_TraceLogAdd 0, 0, "**** calling xlBook.Close "
xlBook.Close False
vg.Admin_TraceLogAdd 0, 0, "**** calling xlApp.Quit"
xlApp.Quit
vg.Admin_TraceLogAdd 0, 0, "**** deallocating"
set xlSht = Nothing
Set xlApp = Nothing
Set vg=Nothing
Your trace shows:
020730.546 9 1 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs][] timeout=60 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
020734.093 9 1 RunVBScriptFile just started. Handle=33704, Id=3300, StartTime=19/06/2008 02:07:33, HasExited=False
020734.203 9 1 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs], ProcessHandle=[33704], VbsOrExeProcess.WorkingSet=[65536]
020748.734 16 rem vgRemotingCommandLink constructor start, parmameterless
020750.656 18 0 comlg **** calling CreateObject Excel.Application
020755.250 18 0 comlg **** calling WorkBooks.Open
and the trace "**** calling len(strValueEnteredByCaller" never appears..
Top start off the scripts are running very slow on your system. You should make sure that your system is fast enough and that nothing else is using the CPU or Memory too much.
Net you should test VBScripts outside VoiceGuide first to confirm that they execute fine, and the once you have them working then you can try running them in VoiceGuide again.
Your trace shows:
I have done as you suggested and I have tested the program outside VoiceGuide (see attached VoiceGuideExample2.txt) and the program returns a Success and Fail.
I have also rerun the script, the VgEngine log now displays the trace "**** calling len(strValueEnteredByCaller"
vgEngine2.txt
Trace now shows that the VBScript runs and completes, although it still takes a long time to start and perform the CreateObject(Excel.Application)
Perhaps you should look at using a database instead, it would probably be faster to perform a search in a database.
111419.078 9 1 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs], ProcessHandle=[33624], VbsOrExeProcess.WorkingSet=[65536]
111432.671 18 0 comlg **** calling CreateObject Excel.Application
111447.562 18 0 comlg **** calling WorkBooks.Open
111450.765 18 0 comlg **** calling xlApp.ActiveSheet
111450.781 18 0 comlg **** calling len(strValueEnteredByCaller)
111450.796 18 0 comlg **** scaning through all entries until match found or a blank cell is reached
111450.890 18 1 cl Run_ResultReturn [fail]
Thank you for your efforts so far, could you explain why the VBScript is taking the fail path and not the success path when I am inputting a valid number that is stored in the excel spreadsheet?
The excel spreadsheet I'm testing has only 4 cells with information in it (2 in column 1 and 2 in column 2,), the system I am using is Windows XP (SP2), Processor 1.2Ghz, Memory 128mb. Is this Spec a bare minimum?
When I replace the variable $RVSecurity Code on the "StrEnteredByCaller" line of my code with for example 12345 (which I know is in a cell in the excel spreadsheet) the VBScript follows the success path, could you have a look at the syntax around $RVSecurity Code?
$RVSecurity Code is an invalid expression. You need to use:
I think we fixed that line for you before in the example we provided. Please see post #5 in this thread.
I have tried that already with no joy, any ideas?
I have attached a copy of the VBScript I'm tryung to run, a log file showing success path (with hardwired result) and a fail path using "RV[secirity Code]" and the VoiceGuide script I'm trying to run.
vbscript2006.txt
0620vgEngine.txt
TASPIN_SCRIPT.vgs
if using
strValueEnteredByCaller = 12345
results in correct operation then maybe try:
strValueEnteredByCaller = $RV[security Code]
(ie: without the quoted around the $RV[security Code])
Adding tracing to the script should let you debug your script and trace though it in detail to narrow down why the script is executing the way it is.
if using
Excellent, I tried without quotations and it worked, thank you very much for your help
