Ip Telephone
First i would like to thank all supportteam members for powerfull support
i want to transfer call to ip telephone
what steps to be done to achieve that
If you want to use VoIP then the best approach is to use v7 of VoiceGuide and run it on HMP VoIP drivers. Otherwise you would need to use an extern al Media Gateway to convert the Analog (or T1/E1) lines to VoIP.
