Vb Script Case Statement
When I use this Case statement form, VG give me error
my_number = 10
Select Case my_number
Case 1 to 10 : do something
End Select
when I use this Form it's working
my_number = 10
Case 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 : do something
End Select
but the second one is long
You should confirm if the first attempt is valid VBScript syntax.
You can test VBSscripts outside VoiceGuide by just saving them in a .vbs file and double clicking on that file. Windows itself will then try to run a VBScript.
