Developing A New Telephony Application...
Jon Spector wrote:
I am developing a new telephony application, and am interested in
understanding whether I could use Voiceguide to do it.
I'd like to keep an Access database of registered phone numbers. Upon
receiving a call from a registered number I want to forward the call to
an outside number and record the details of the call (time, date,
length) in an Access database. Speed is the primary criteria I am
interested in - answering the call before the first ring if possible,
identifying the calling party immediately (using caller-ID?), and
forwarding it immediately if the phone number is in the registered
database.
If the number is not found in the database then it would branch to a
message, or perhaps an IVR menu with some options, and I would handle
the call without forwarding to the outside number. I'm sure Voiceguide
can do this part.
So my questions are:
1. I noticed in the knowledge base somewhere that the speed of
answer (with caller-ID enabled) may be slower on some modems, or perhaps
on all modems (?) - so can you comment on that as well and recommend the
fastest hardware I might buy?
2. I'm not a telephony expert (as should be obvious from my
questions!) - so if there is another solution besides using caller-ID to
identify the person calling, that would be very helpful. In particular,
is there other information other than caller ID that I can pull off an
incoming call to identify the caller without the caller having to input
anything? FYI - I am prepared to use whatever incoming lines I need to
facilitate this service - e.g. PRI - if it won't work on regular analog
phone lines.
3. Re: hardware - how many lines can a fast PC running Voiceguide
handle with no perceptible delay? I see from the modem side I can buy a
modem with 16 ports (or maybe 24?). What are the PC requirements
(processor speed, memory) to handle this volume simultaneously with no
perceptible delays? Or do I need to split it up across several
machines?
4. After I forward the call - am I tying up two phone lines, or
none?
5. What would be the cost of a Voiceguide license to handle 24 or
48 incoming lines, with call forwarding capability?
6. And finally - if Voiceguide can indeed handle the above
requirements, do you provide customer development for solutions like
this?
I realize there are a lot of questions here, but based on my cursory
look at competing apps it seems that Voiceguide may be a very
cost-effective way for me to tackle this situation, and I'd like to
learn more.
Thanks.
Jon Spector
A PRI (T1) connection will allow you to answer the call immediately - there will always be a delay of at least around a second on analog connections.
Caller ID is it... there is no other information sent from the telephone company to identify the caller.
machines?
A fast PC (2GHz, 512MB RAM) will easily handle 60 simultaneous calls. You should not use modems for such size applications - you will need a Dialogic card (D240).
none?
As you are using Digital connections the simplest way to forward a call is to have a second call made on another line and have the two calls 'conferenced' together - so the answer is 2.
5. What would be the cost of a VoiceGuide license to handle 24 or
24 line VoiceGuide Professional+Dialer $2499
48 line VoiceGuide Professional+Dialer $3699
this?
We offer script development services - VoiceGuide is however quite easy to work with and you will probably find you’ll need no outside assistance in creating the script - VoiceGuide has been designed to be pretty intuitive - if after using it for a while you feel you still need some assistance in developing your application please post your requirements here and we can indicate the costs involved if our staff were to create the script.
