Problem Forwarding Vm Messages
Hello,
I have set up VG on a clean win 98 box, 128meg Ram PIII400 and have it up and running. I can call in, use the menus I have set up, leave messages and retrieve messages. The problem I am having is when the system tries to forward the messages to me cell phone. The recorded announcement plays and instructs me to press 1 to play messages. When I do that all I hear is garbled noise and the system get stuck. I have tried both the scripted and built-in methods of forwardin and neither seem to work. Any suggestions?
Thanks,
Jay
Sounds like the recorded voicemail message does not want to play back correctly when delivering the message on the outbound call – but you can listen to the same message when you dial into the system....
Does this garbled noise happen every time the message is delivered on an outbound call? Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
Some modems will sometimes play garbled noise instead of the sound file - but on modems we've seen this only tended to happen randomly (and rarely), and wasn't linked to a particular sound file or order of events - also the modems did not get 'stuck' afterwards...
The only solution if you find that your modem isn't working well for you is to find another modem...
Here is the log. I placed a call, recorded a message then let the system call my cell phone to forward the message. I places a row of ***** at the point where it gets stuck. The application will email me message files and as I said before, I can dial in and retrieve them.
123144.81 0 Play End line[0] (id=590847)
123144.81 0 LsVmRetr_ListenMsgs2 EV_PLAY_FINISHED
123144.86 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbAccessListenMsgMenu.wav]
123148.76 0 dtmf 3 (51,2)
123148.76 0 LsVmRetr_ListenMsgs 3
123149.48 0 PlaySoundStop ok
123149.48 0 VmbMsgList:[23_0902122151_1_0__.wav]
123149.48 0 vmb VmbMsg 1 23_0902122151_1_0__.wav
123149.53 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\23_0902122151_1_0__.wav]
123157.66 0 Play End line[0] (id=603677)
123157.66 0 LsVmRetr_ListenMsgs2 EV_PLAY_FINISHED
123157.72 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbAccessListenMsgMenu.wav]
123200.46 0 dtmf 3 (51,2)
123200.46 0 LsVmRetr_ListenMsgs 3
123201.07 0 PlaySoundStop ok
123201.07 0 VmbMsgList:[]
123201.12 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbAccessNoNewMessages.wav,C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbAccessMenu.wav]
123213.92 0 Play End line[0] (id=615244)
123213.92 0 LsVmRetr_MenuPlay EV_PLAY_FINISHED
123219.36 0 LsVmRetr_MenuPlay EV_TIMEOUT_REPLAYMSG
123219.41 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbAccessMenu.wav]
123230.18 0 Play End line[0] (id=633533)
123230.18 0 LsVmRetr_MenuPlay EV_PLAY_FINISHED
123241.11 0 LsVmRetr_MenuPlay EV_TIMEOUT_HANGUP
123241.11 0 Hanging up call...
123241.16 0 RecSoundStop ok
123241.16 0 PlaySoundStop ok
123241.77 0 fnHangupCall end
123241.77 0 callstate IDLE 4330184 0 0
123241.77 0 WorkingMode@Idle=
123241.82 0 tapi Reply 8 0
123242.87 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123242.87 0 ReinitTelephony due to IDLE start
123242.92 0 tapic lineDeallocateCall(MainCall:4330184) 0
123244.90 0 lineOpen(0) => 0
123244.90 0 Waiting for a call...
123244.90 0 lineOpen(0)LineHandle=4328640
133542.45 0 callstate OFFERING 4328960 0 4
133542.51 0 ring 1
133542.51 0 Answer the call at 9/2/03 1:35:42 PM
133542.51 0 lineAnswer(4328960) => 1
133542.56 0 tapi Reply 1 0
133542.56 0 callstate ACCEPTED 4328960 0 0
133542.95 0 callstate CONNECTED 4328960,0,0
133542.95 0 WorkingModeTAPI=
133542.95 0 WorkingModeScript=
133542.95 0 Inband detection not enabled
133542.95 0 StartLoadedVgs at 9/2/03 1:35:42 PM
133543.00 0 [MainGreeting] Number Input
133543.00 0 [MainGreeting] Playing (C:\Program Files\VoiceGuide\data\SPCVoiceMail\Audio\SPC-main8000Mono.wav)
133543.22 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\SPCVoiceMail\Audio\SPC-main8000Mono.wav]
133547.56 0 dtmf 2 (50,2)
133547.62 0 LsGetNbrsPlayWelcMsg 2
133548.22 0 PlaySoundStop ok
133548.22 0 [MainGreeting] Number Input 2
133548.22 0 dtmf 3 (51,2)
133548.22 0 LsGetNbrsRxDigits 3
133548.22 0 [MainGreeting] Number Input 23
133548.28 0 [23-Marketing] Playing
133548.28 0 [23-Marketing] Playing (C:\Program Files\VoiceGuide\data\SPCVoiceMail\VmBoxes8000\Jay8000.wav)
133548.33 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\SPCVoiceMail\VmBoxes8000\Jay8000.wav]
133548.39 0 RunModule PLAY end
133553.71 0 Play End line[0] (id=996425)
133553.71 0 LsPlayMsg EV_PLAY_FINISHED
133554.76 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
133554.76 0 Built-in voicemail used.
133554.76 0 [23] Playing Welcome Message
133554.87 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbWelcomeMsgDefault.wav]
133557.72 0 Play End line[0] (id=2931)
133557.72 0 LsVmLm_PlayWelc EV_PLAY_FINISHED
133557.78 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\beep1.wav]
133558.22 0 Play End line[0] (id=5884)
133558.22 0 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
133558.22 0 RecSoundStart file[C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\23_0902133558_1_0__.wav] ok
133558.27 0 Voicemail_MaxRecLength=120.
133558.27 0 [23] Recording Message
133610.25 0 LsVmLm_Rec EV_SILENCE_DETECTED
133610.25 0 Silence Detected
133610.30 0 LsVmLm_Rec EV_REC_FINISHED
133610.30 0 vm frwrd vmb 23
133610.30 0 vm frwrd phone: 4714701 (builtin system)
133610.30 0 DialListDB_AddCall '4714701', 0, 1, 2359, MoTuWeThFrSaSu, C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav, NEWEST_VOICEMAIL_MESSAGE:23, NEWEST_VOICEMAIL_MESSAGE:23, [PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[VmbId]{23}[VmFileToPlay]{C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\23_0902133558_1_0__.wav}, 60, 2, 5 ESCALATION:
133610.47 0 Hanging up call... [srvm1]
133610.52 0 RecSoundStop ok
133610.52 0 PlaySoundStop ok
133611.13 0 fnHangupCall end
133611.13 0 callstate IDLE 4328960 0 0
133611.18 0 WorkingMode@Idle=
133611.18 0 tapi Reply 2 0
133612.33 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
133612.33 0 ReinitTelephony due to IDLE start
133612.39 0 tapic lineDeallocateCall(MainCall:4328960) 0
133614.53 0 lineOpen(0) => 0
133614.53 0 Waiting for a call...
133614.53 0 lineOpen(0)LineHandle=4328560
133619.53 0 dial callque update id=9 next call time 0309021341
133619.58 0 dial found entry: tel[4714701] ann[C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav] vgs[NEWEST_VOICEMAIL_MESSAGE:23] am[NEWEST_VOICEMAIL_MESSAGE:23]
133619.58 0 Dialing: 4714701
133620.57 0 MakeCall => 3
133620.57 0 TapiCbTrigSet 3 7002
133622.99 0 tapi Reply 3 0
133622.99 0 TapiCbTrigClear
133623.04 0 callstate DIALTONE 4329576 32 0
133623.04 0 callstate DIALING 4329576 0 0
133623.04 0 callstate PROCEEDING 4329576 0 0
133624.58 0 callstate CONNECTED 4329576,0,0
133624.58 0 WorkingModeTAPI=
133624.58 0 WorkingModeScript=
133624.58 0 Dialing: Playing introduction message
133624.69 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav]
133632.44 0 Play End line[0] (id=32735)
133632.44 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
133632.55 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav]
133636.06 0 dtmf 1 (49,2)
133636.06 0 LsDialoutPlayAcceptAuto 1
133636.67 0 PlaySoundStop ok
133636.72 2 tr NewVgsVgm_Goto NEWEST_VOICEMAIL_MESSAGE:23,,,,,0
133636.72 0 dial callque delete id=9
************************Gets Stuck HERE************************
133714.07 0 btn Hangup on line 0
133714.07 0 LsDialoutPlayAcceptAuto EV_TIMEOUT_HANGUP
133714.07 0 Hanging up call...
133714.12 0 RecSoundStop ok
133714.12 0 PlaySoundStop ok
133714.29 0 Waiting for a call...
133714.29 0 fnHangupCall end
133714.29 0 callstate IDLE 4329576 0 0
133714.29 0 WorkingMode@Idle=
133714.29 0 LineState(iLineId).iVgsIdx = 0
133714.34 0 tapi Reply 4 0
133715.39 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
133715.39 0 ReinitTelephony due to IDLE start
133715.39 0 tapic lineDeallocateCall(MainCall:4329576) 0
133717.48 0 lineOpen(0) => 0
133717.48 0 Waiting for a call...
133717.48 0 lineOpen(0)LineHandle=4328560
Can you please try running the test when using the 'scripted' voicemail system and post the trace here,
Some other users have reported issues when using two digit voicemail box IDs - not too sure what these were right now but can you also please try using a 4 digit Voicemail box ID (eg: "0001") and post a trace of a forwarded call from that mailbox (when using the scripted system)
(if possible please download currently available v5.1 Beta1 and try with this version)
Here is the log from using a four-digit VM box and the scripted forwarding method. The system stil gets stuck at the same point. I have downloaded the beta but have not had a chance to install it.
174842.10 0 callstate OFFERING 4328960 0 4
174842.10 0 ring 1
174842.10 0 Answer the call at 9/3/03 5:48:42 PM
174842.10 0 lineAnswer(4328960) => 1
174842.10 0 tapi Reply 1 0
174842.10 0 callstate ACCEPTED 4328960 0 0
174842.54 0 callstate CONNECTED 4328960,0,0
174842.54 0 WorkingModeTAPI=
174842.54 0 WorkingModeScript=
174842.54 0 Inband detection not enabled
174842.54 0 StartLoadedVgs at 9/3/03 5:48:42 PM
174842.54 0 [MainGreeting] Number Input
174842.54 0 [MainGreeting] Playing (C:\Program Files\VoiceGuide\data\SPCVoiceMail\Audio\SPC-main8000Mono.wav)
174842.60 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\SPCVoiceMail\Audio\SPC-main8000Mono.wav]
174848.75 0 dtmf 2 (50,2)
174848.75 0 LsGetNbrsPlayWelcMsg 2
174849.30 0 PlaySoundStop ok
174849.30 0 [MainGreeting] Number Input 2
174849.30 0 dtmf 3 (51,2)
174849.30 0 LsGetNbrsRxDigits 3
174849.30 0 [MainGreeting] Number Input 23
174849.30 0 [23-Marketing] Playing
174849.30 0 [23-Marketing] Playing (C:\Program Files\VoiceGuide\data\SPCVoiceMail\VmBoxes8000\Jay8000.wav)
174849.35 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\SPCVoiceMail\VmBoxes8000\Jay8000.wav]
174849.35 0 RunModule PLAY end
174854.68 0 Play End line[0] (id=374424)
174854.68 0 LsPlayMsg EV_PLAY_FINISHED
174856.11 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
174856.16 0 Built-in voicemail used.
174856.16 0 [0023] Playing Welcome Message
174856.22 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbWelcomeMsgDefault.wav]
174859.07 0 Play End line[0] (id=381267)
174859.07 0 LsVmLm_PlayWelc EV_PLAY_FINISHED
174859.13 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\beep1.wav]
174859.57 0 Play End line[0] (id=384203)
174859.57 0 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
174859.57 0 RecSoundStart file[C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0023_0903174859_1_0__.wav] ok
174859.62 0 Voicemail_MaxRecLength=120.
174859.62 0 [0023] Recording Message
174907.59 0 LsVmLm_Rec EV_SILENCE_DETECTED
174907.59 0 Silence Detected
174907.64 0 LsVmLm_Rec EV_REC_FINISHED
174907.64 0 vm frwrd vmb 0023
174907.70 0 vm frwrd phone: 4714701 (builtin system)
174907.70 0 DialListDB_AddCall '4714701', 0, 1, 2359, MoTuWeThFrSaSu, C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav, NEWEST_VOICEMAIL_MESSAGE:0023, NEWEST_VOICEMAIL_MESSAGE:0023, [PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[VmbId]{0023}[VmFileToPlay]{C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0023_0903174859_1_0__.wav}, 60, 2, 5 ESCALATION:
174907.70 0 Hanging up call... [srvm1]
174907.70 0 RecSoundStop ok
174907.70 0 PlaySoundStop ok
174908.36 0 fnHangupCall end
174908.36 0 callstate IDLE 4328960 0 0
174908.41 0 WorkingMode@Idle=
174908.41 0 tapi Reply 2 0
174909.51 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
174909.51 0 ReinitTelephony due to IDLE start
174909.51 0 tapic lineDeallocateCall(MainCall:4328960) 0
174911.54 0 lineOpen(0) => 0
174911.54 0 Waiting for a call...
174911.54 0 lineOpen(0)LineHandle=4328560
174916.65 0 dial callque update id=11 next call time 0309031754
174916.71 0 dial found entry: tel[4714701] ann[C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav] vgs[NEWEST_VOICEMAIL_MESSAGE:0023] am[NEWEST_VOICEMAIL_MESSAGE:0023]
174916.71 0 Dialing: 4714701
174917.58 0 MakeCall => 3
174917.58 0 TapiCbTrigSet 3 7002
174920.00 0 tapi Reply 3 0
174920.00 0 TapiCbTrigClear
174920.00 0 callstate DIALTONE 4329576 32 0
174920.00 0 callstate DIALING 4329576 0 0
174920.00 0 callstate PROCEEDING 4329576 0 0
174921.54 0 callstate CONNECTED 4329576,0,0
174921.54 0 WorkingModeTAPI=
174921.54 0 WorkingModeScript=
174921.54 0 Dialing: Playing introduction message
174921.59 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav]
174929.34 0 Play End line[0] (id=406666)
174929.34 0 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
174929.39 0 PlaySoundStart ok [C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbForwardAskAccept.wav]
174935.22 0 dtmf 1 (49,2)
174935.22 0 LsDialoutPlayAcceptAuto 1
174936.09 0 PlaySoundStop ok
174936.09 2 tr NewVgsVgm_Goto NEWEST_VOICEMAIL_MESSAGE:0023,,,,,0
174936.09 0 dial callque delete id=11
*****************Gets stuck here************************
174952.52 0 btn Hangup on line 0
174952.52 0 LsDialoutPlayAcceptAuto EV_TIMEOUT_HANGUP
174952.52 0 Hanging up call...
174952.52 0 RecSoundStop ok
174952.52 0 PlaySoundStop ok
174952.68 0 Waiting for a call...
174952.68 0 fnHangupCall end
174952.68 0 callstate IDLE 4329576 0 0
174952.68 0 WorkingMode@Idle=
174952.74 0 LineState(iLineId).iVgsIdx = 0
174952.74 0 tapi Reply 4 0
174953.78 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
174953.78 0 ReinitTelephony due to IDLE start
174953.78 0 tapic lineDeallocateCall(MainCall:4329576) 0
174955.76 0 lineOpen(0) => 0
174955.81 0 Waiting for a call...
174955.81 0 lineOpen(0)LineHandle=4328560
I notice the trace was still done using the 'built-in' voicemail system. Can you please try running the test when using the default 'scripted' voicemail system.
