View Logs
we have customer use VG V6.0.3377
when we press the view logs button it was not work because the VgLv applications was not found , then i copy this application from VG V6.0.0.3003 and paste it , its work( the time and date and detail appeared) but not all numbers appeared only 20 numbers appears from 300 numbers
i try to call from my mobile then check the logs , the date and time and detail appeared but the number not appeared , there's another mobile number appeared .
Please post the .vgl log file.
We'll look into the reason why the Log Viewer application is not launching when started from the Script Designer. Most likely it's because the name of the Log Viewer application itself was changed.
