Return
I have been unable to make the voicemail system module (GetNumbers4) with in my script return to the main menu (Play 2) of script. I have attached a copy of my script and would like to know if it is possible for someone to check my path in voicemail system module (GetNumbers4)
On {Success} Goto [Voicemail Box $RV[GetNumbers4]] Return [Play 2]
On {Fail} Goto [Play 7]
On {Timeout 10} Goto [Play 7]
The path looks fine.
Are you trying to return by pressing "0" from the main voicemail menu or are you trying to return from a different part of the Voicemail system?
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
