Adding Multiple Users To Voicemail Config
Grzegorz wrote:
I would like to ask if I can add more then one user to VMB in the same time.
Now I can add one user, set up configuration and then go to add another user etc. Is in VM Manager any option to do this multiple adding users?
It is not possible to add multiple mailboxes using the Voicemail Manager at the same time. Each new mailbox requires for you to enter the mailbox number and then press the "Add" button next to the text box in which the mailbox number was entered.
You can edit the VmBoxList.xml file directly as well.
