Vbs Module
Please, I need help with a VBS module that works making a "do while" reproduce then each of the recovered information.
I don't understand because it does not work.
For example, look at this VBS code:
SQLConnStr = "$RV[ConnStr]"
Conn.Open SQLConnStr
StrSQL = "SELECT CodigoPago from telepago WHERE SocioNum = " & CustId
Set Rs = Conn.execute(StrSQL)
If Rs.Eof or Rs.Bof Then
'No codes availables
Else
NroReg = 0
Do while Not Rs.EOF
NroReg = NroReg + 1
CodigoPago = Rs.fields("CodigoPago").Value
StrSQL = "SELECT FileDeLectura from CodigoCuentas where CodigoPago = " & CodigoPago
Set Rs2 = Conn.Execute(StrSQL)
If Rs2.Eof or Rs2.Bof Then
'No data in this query
Else
Rs2.MoveFirst
FileDeLectura = Rs2.Fields("FileDeLectura").Value
vg.RvSet LineID,"FileDeLectura",FileDeLectura
vg.Script_Goto iLineId,"","LeerCodigoConfirmacion","" 'This program ends here in abnormal form
End If
Rs.MoveNext
Loop
End If
If you could post the entire script then we can better answer your question, but I think the reason why you are having problem on line
is because iLineId is not holding the actaul LineID value.
Try:
vg.Script_Goto $RV_LINEID,"","LeerCodigoConfirmacion",""
Also change:
to be
vg.RvSet $RV_LINEID,"FileDeLectura",FileDeLectura
Also change:
to be
I did the changes and they did not do effect, the program continues ending badly
Could you please post a copy of VoiceGuide's Trace Logs which captures the call, this will allow us to see what happened.
[Log]
VoiceGuide=10
