Pc Restarts Itself
Pradeep Sabharwal wrote:
The system configuration is P-III 800 Mhz, 128 MB RAM, Win2000 Proessional and D-Link Data,Fax,Voice, Speaker Phone Internal Modem with Conexant SoftK56 Driver. And when we tested your package our system resarted thrice. Can you sort out this problem urgently because we have to finalize this purchase by Wednesday.
If a PC restarts that means that there is something wrong with the modem driver - only the modem driver runs in a privileged enough state to be able to do actions which result in PC restart - I'd recommend getting a different modem or (better) a Dialogic card..
Or it could be bad memory chips in your PC... so maybe you should try another PC...
We have not had any reports of PC reboot due to VoiceGuide - and indeed an application like VoiceGuide cannot cause a problem that results in a PC reboot... not on Win2000
rebooting could be some kind of bluescreen...
try disabling automatic restart, to get some information about the kind of bluescreen...
probably it is some broken ram or modem drivers...
