Having System Answer Only At Certain Times
Amy wrote:
We don't start the program while we are in business. We don't want any voicemail up during business hours. However we want the program to automatically answer starting at 6:00 pm Monday-Friday and all day Sat & Sun.
Any suggestions?
The script should be setup to "Start without answering the call", and then the first module should be a Time Switch module.
Use the Time Switch module to rout calls to either the rest of the script (the part that does the voicemail etc) or route the call to a Hangup module.
If you route the call to the hangup module the script will end without ever answering the call.
See attached sample script which demonstrates the approach.
AfterOfficeHours.vgs
