Voice Message Does Not Work W/ Sprint Voice Mail
We've been able to install VG7 and its working really good so far.
We have 4 lines with a Dialogic Card D41JCT
The only problem we're having is when I call Sprint/Nextel cell phones for some reason VG does not recognize properly the Voice Mail feature. My script basically call the phone number, play a 30 seconds wave file and hang up. I'm using the dialer to do it. But it starts to play my wav file before the Voice Mail Greeting ends. In other words they always get half message from voice mail.
Attached the config file.
Thank you, :rolleyes:
Alex
Files.zip
Attached log files do not capture any outgoing calls, so it's hard to say what happened on the outgoing calls. It is possible that the Dialogic card though the answering machine was a live human, and did not therefore wait till end of welcome message.
BTW: Trace shows that you are using an unregistered version of VoiceGuide:
155109.162 5 no license file c:\Program Files\VoiceGuide7\userinfo.lic
There is a limited number of outbound calls that can be made with an unlicensed version of VoiceGuide.
This is my config file. Do I need to change something about Silence Detect?
Thank you,
Alex
vg.zip
Enable logging by setting the log levels to 10 in VG.INI as per below. (these settings are set by default in v7 of VoiceGuide)
[Log]
VoiceGuide=10
ktTel=10
Most likely the traces will show that the Dialogic card thought the answering machine was a live human, and did not therefore wait till end of welcome message. Using an extra record module in your script would force the module to wait until the welcome message is finished, and then use the "silence" path to move onto the Play module to play the message.
So far is working well. We changed the vg.ini the silence configuration.
Now I'm trying to buy your product. But we only need 2 lines for V7
Please someone call me from sales department.
Thank you,
Alex
800-899-4852
Ext. 5010
