Outdial_uncontactable_noanswer.txt
Hi
I want to dial numbers and check the numbers are live.
So I am hoping to get them apear in OutDial_Uncontactable_NoAnswer.txt when they ring, I have short ring so should not be answered.
However they appear in OutDial_Uncontactable_Error.txt
But my mobile rings 3 times so I would like to think it would appear in OutDial_Uncontactable_NoAnswer.txt
Also I have answer timeout of 1, is there a possibility to shorten this at the moment its rings 3 times I would prefer once, twice max.
08:44 PM 27/11/07, "00447967049457", 0, 2, NONE, C:\Program Files\VoiceGuide\Scripts\hangup.vgs, C:\Program Files\VoiceGuide\Scripts\hangup.vgs, none[OutDial_RetriesLeft]{0}
Here is the log.
204438.45 4 dial [145,00447967049457,711271957,1,2359,MoTuWeThFrSaSu,[,,1,,],1,NONE,C:\Program Files\VoiceGuide\Scripts\hangup.vgs,C:\Program Files\VoiceGuide\Scripts\hangup.vgs,none,1,0,0,,none] (search started at 204438.45)
204438.45 4 dial DialOnLine start tel[00447967049457] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\hangup.vgs] am[C:\Program Files\VoiceGuide\Scripts\hangup.vgs] rv[none] cid[]
204438.45 4 rv clear all
204438.45 4 rv add [OutDial_RetriesLeft]{0}
204438.45 4 dial making call tel[00447967049457] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\hangup.vgs] am[C:\Program Files\VoiceGuide\Scripts\hangup.vgs] OnHangup[] rv[none[OutDial_RetriesLeft]{0}]
204438.45 4 script interpretor: VgMulti v6.0.3310
204438.45 4 state Dialing 00447967049457
204438.45 4 lineMakeCall=>[]
204438.45 4 timer set 10 EV_TIMEOUT_MAKECALL_NORESPONSE
204448.45 4 tw DialogicEvent 2086,GCEV_DISCONNECTED,2086,0,0,GCRV_NOANSWER,event caused by no answer,No user responding
204448.45 4 event GCEV_DISCONNECTED, iCode=2086 state=5200
204448.45 4 LsWaitAfterDialingOut : 2086,GCEV_DISCONNECTED,2086,0,0,GCRV_NOANSWER,event caused by no answer,No user responding
204448.52 4 tw DialogicEvent 2053,GCEV_DROPCALL,2053,0,0,,,
204448.52 4 event GCEV_DROPCALL, iCode=2053 state=5200
204448.52 4 LsWaitAfterDialingOut : 2053,GCEV_DROPCALL,2053,0,0,,,
204448.52 4 tw DialogicEvent 2137,GCEV_RELEASECALL,2137,0,0,,,
204448.52 4 event GCEV_RELEASECALL, iCode=2137 state=5200
204448.52 4 LsWaitAfterDialingOut : 2137,GCEV_RELEASECALL,2137,0,0,,,
204448.52 4 event callstate IDLE 4 1,0,0
204448.52 4 WorkingMode@Idle=
204448.52 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
204448.52 4 DialoutProcessFailedDial start sCalledFrom=[LineEvCallState-LINECALLSTATE_IDLE] RetriesLeft=0
204448.52 0 dial callque delete id=145 (MSAccess)
204448.52 4 rvns add [OutDial_Result]{Uncontactable_Error}
204448.52 4 timer clear
204448.52 4 dial no escalation info
204448.52 4 LineState(iLineId).iVgsIdx = 0
204448.52 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
204448.62 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
204448.62 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=5200
204448.62 4 init atidle reinit : start
204448.62 4 init atidle reinit iConferenceOtherLegLid=-1
204448.62 4 init atidle reinit : reset all LineState variables
204448.62 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
204448.62 4 state Waiting for a call...
204450.80 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
204450.80 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=5200
204450.80 4 setting iDialoutReadyToDialout = 1
204813.66 0 sys cleanup Start
204813.66 0 sys cleanup End
204438.446 004 ocxfn LineMakeCall(linedev=4, hcall=0, 00447967049457, callprog=DX_PAMDOPTEN, timeout=10, params:[0,0,cid=,]) chdev=5, dtidev=3
204438.446 004 makecall protocol is: non-ISDN
204438.446 route resources (dtiB1T1) call
204438.446 dlgc dxxx not found in device name [dtiB1T1] - must be dti name
204438.446 004 attach resource dxxxB1C1:5 to dtiB1T1:3 (linedev=4)
204438.446 004 continue as ct_devfamily=CT_DFDM3
204438.446 004 outgoing cid is blank. SetCallingNum not called.
204438.446 004 gc makecall defsrc none ()
204438.446 004 gc gc_MakeCall(00447967049457) call
204438.446 004 gc gc_MakeCall(4, [00447967049457], 10) ok
204438.446 004 call progress detection not enabled. We'll wait till after connect
204438.477 004 ev GCEV_ATTACH
204438.477 004 ResultInfo gcValue=1280(0x500) gcMsg=[Normal completion] ccLibId=6 ccLibName=[GC_DM3CC_LIB] ccValue=[0x0|GCRV_NORMAL|normal completion ] ccMsg=[No Error] additionalinfo=
204438.539 004 ev GCEV_PROCEEDING
204438.539 004 ResultInfo gcValue=1280(0x500) gcMsg=[Normal completion] ccLibId=6 ccLibName=[GC_DM3CC_LIB] ccValue=[0x0|GCRV_NORMAL|normal completion ] ccMsg=[No Error] additionalinfo=
204444.524 004 ev GCEV_PROGRESSING
204448.446 004 ev GCEV_DISCONNECTED
204448.446 004 gc GCST_DISCONNECTED status gc:65:[Function is not supported in this state], cc_err=32777 cclibid=6
204448.446 004 ResultInfo gcValue=1284(0x504) gcMsg=[Event caused by no answer] ccLibId=6 ccLibName=[GC_DM3CC_LIB] ccValue=[0x312|GCRV_NOANSWER|event caused by no answer] ccMsg=[No user responding] additionalinfo=
204448.446 005 dx_stopch call in GCEV_DISCONNECTED
204448.446 005 dx_stopch 5 ok
204448.446 004 gc gc_DropCall(crn=101515268, GC_NORMAL_CLEARING) (on Disconnected event)
204448.446 004 gc gc_DropCall ok
204448.446 004 ocxev DoFireDialogic(dwIdx=2403, 4, 2086, [GCEV_DISCONNECTED], 2086, 0, 0, [GCRV_NOANSWER], [event caused by no answer], [No user responding]) (dwIdx=2403)
204448.446 004 ocxev DoFireDialogic completed
204448.524 004 ev GCEV_DROPCALL
204448.524 004 gc gc_ReleaseCallEx ok
204448.524 004 ev GCEV_RELEASECALL
204448.524 004 ocxev DoFireDialogic(dwIdx=2404, 4, 2053, [GCEV_DROPCALL], 2053, 0, 0, [], [], []) (dwIdx=2404)
204448.524 004 ocxev DoFireDialogic completed
204448.524 004 ocxev DoFireDialogic(dwIdx=2405, 4, 2137, [GCEV_RELEASECALL], 2137, 0, 0, [], [], []) (dwIdx=2405)
204448.524 004 te LINE_CALLSTATE(4, 0x4, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
204448.618 004 ocxfn RingsBeforeAnswer(lLineId=4, lRings=0, lParam1=0, strParam2=)
Tony
Which version of VoiceGuide v6 is used on this system?
Please download the latest version of v6 from our WWW and us this version.
Please post traces as before if call record is still saved in the wrong log file.
