Vbs Script Examples
Hi, i need an example of a vbs script that wil query a dbase3 database and return the results to voiceguide to be read back to the caller.Any help would be greatly appreciated.
Here are a few useful links:
HOW TO: Use Jet OLE DB Provider 4.0 to Connect to ISAM Databases
http://support.microsoft.com/kb/326548
and:
http://www.voiceguide.com/vghelp/source/html/modvbs.htm
eg:
set cn = CreateObject("ADODB.Connection")
cn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\somepath;Extended Properties=DBASE III;"
if cn.State <> 1 then
vg.Admin_TraceLogAdd iLineId, 5, "login connection to database could not be made"
vg.Run_ResultReturn iLineId, "fail"
WScript.Quit
end if
set rs.ActiveConnection = cn
sSQL = "SELECT TOP 1 AdID, Filename, PlayCount, LastPlayTime FROM AdList WHERE PlayCount < PlayCountMax AND Active <> 0 ORDER BY LastPlayTime"
rs.Open sSQL, cn, 3
if rs.RecordCount <= 0 then
rs.Close
vg.Admin_TraceLogAdd iLineId, 5, "no records retrieved"
else
iAdID = rs.Fields("AdID").Value
sFilename = rs.Fields("Filename").Value
iPlayCount = rs.Fields("PlayCount").Value
dateLastPlayTime = rs.Fields("LastPlayTime").Value
rs.Close
strResultVars= "[Filename]{" & sFilename & "}[LastPlayTime]{" & dateLastPlayTime & "}"
vg.Run_ResultReturn $RV_LINEID, strResultVars
end if
cn.Close
set rs = Nothing
set cn = Nothing
set vg = Nothing
And you can then use $RV[Filename] and $RV[LastPlayTime] in the VoiceGuide script.
