Config.xml Help
hi, i cannot register VG (on WinXP sp2 PC) as SIP extensions behind my IP-PBX. Could you please help with the config.xml? Thanks a lot.
IP-PBX IP: 192.168.8.80
SIP Ext 1: 2001 ID: 2001 Password: 2001
SIP Ext 2: 2002 ID: 2002 Password: 2002
<?xml version="1.0" ?>
- <VoiceGuideConfig>
- <Devices_Dialogic>
- <Channels>
- <Channel>
<Device_Voice>dxxxB1C1</Device_Voice>
<Device_Network>iptB1T1</Device_Network>
<Device_Media>ipmB1C1</Device_Media>
<Protocol>IP</Protocol>
<script>C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\Credit Card Payment.vgs</Script>
</Channel>
- <Channel>
<Device_Voice>dxxxB1C2</Device_Voice>
<Device_Network>iptB1T2</Device_Network>
<Device_Media>ipmB1C2</Device_Media>
</Channel>
- <Channel>
<Device_Voice>dxxxB1C3</Device_Voice>
<Device_Network>iptB1T3</Device_Network>
<Device_Media>ipmB1C3</Device_Media>
</Channel>
- <Channel>
<Device_Voice>dxxxB1C4</Device_Voice>
<Device_Network>iptB1T4</Device_Network>
<Device_Media>ipmB1C4</Device_Media>
</Channel>
</Channels>
<Parms />
</Devices_Dialogic>
- <VoIP_Lines>
- <VoIP_Registrations>
- <VoIP_Registration>
<Display>2001</Display>
<Protocol>SIP</Protocol>
<RegServer>192.168.8.80</RegServer>
<RegClient>2001</RegClient>
<LocalAlias>2001</LocalAlias>
</VoIP_Registration>
<Display>2002</Display>
<RegClient>2002</RegClient>
<LocalAlias>2002</LocalAlias>
</VoIP_Registrations>
- <VoIP_Authentications>
- <VoIP_Authentication>
<Domain>192.168.8.80</Domain>
<Username>2001</Username>
<AuthUsername>2001</AuthUsername>
<AuthPassword>2001</AuthPassword>
</VoIP_Authentication>
<AuthUsername>2002</AuthUsername>
<AuthPassword>2002</AuthPassword>
</VoIP_Authentications>
</VoIP_Lines>
</VoiceGuideConfig>
Are you using the latest version of VoiceGuide?
Could you please post a copy of VoiceGuide's Trace Logs which captures the system startup, this will allow us to see what happened.
[Log]
VoiceGuide=10
Then restart VG.
The WireShark Network Protocol Analyzer is often useful in debugging SIP registration and connectivity. See: www.wireshark.org
To use WireShark:
1. Start WireShark
2. Go to 'Capture' menu and select the 'Interfaces' menu option.
3. Select your network interface (press the corresponding Start button)
4. In the Filter window type in these 3 letters: sip
5. Start VoiceGuide.
6. You should now see the SIP registration messages appear in the WireShark trace window.
7. You can save the captured trace and post it here or email it to us to assist in debugging.
Thanks. VG 7 is used. And i updated some settings in config.xml. Please find attached log.zip, it contains \log folder, VG wireshark, and config.xml. Thanks again.
Log.zip
