Polling Voicemail And Forwarding Messages?
Is there a way to have VoiceGuide poll specific voicemail boxes or detect new messages and then forward a call to alert that a message has been received? Thanks for any help.
Ron
Various forwarding options are available, Voicemail messages can be forwarded by:
1. Email,
2. To another phone number,
3. Pager,
4. Copied to another voicemail box
5. Copied to a broadcast list.
All these can be edited on a per-voicemail-box basis using the VoiceGuide Voicemail Manager.
Okay, I must be thick because I cannot find any options that allow the detection of new voicemail messages so I can create a forwarding script.
Can you give me an example, say, if VoiceMailbox 0007 receives a new message whereby it will be automatically forwarded to phone number X to notify the receiver of a new message?
Thanks for your help.
Have you looked at the Voicemail Manager application?
Please read the Help file's section on the "Voicemail System Manager"
I'm using version 4.8.45. I have used the System Manager and assigned a forwarding number to VoiceMailbox 0007. When I call from another line and leave a message to that box, it records the message, but does not forward a call to the number assigned after I hang up.
Yes, I have read the help files, and have found nothing regarding forwarding other than while callers are still on the line.
I need a message forwarded automatically to a number after callers have left a message. I don't need the message sent, just a notification of a message being received.
Like I said, I may be thick, but I see nothing in the help file regarding automatically forwarding message notifications, not have I been able to figure out a workaround.
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem (incoming call + some time afterwards), this will allow us to see what is going wrong.
If you are evaluatting the software, I'd recommend downloading and trying out the v5.0 Beta release - it has a few more options then v4.8
I'm running VgMulti.exe as a service, is that where I get the debug information? Will it hurt anything for me to try opening two instances of it?
Sorry for the delay, and thanks for your help.
in VG.INI file, section [TraceLog] please set the LogToFile entry to 1 :
[TraceLog]
LogToFile=1
The log file will be created in C:\ and will be called C:\VoiceGuideLogMMDD.txt
