Auto Dialler Dualled Number Restriction?
Is there a setting that controls the number of digits dialled in outgoing calls?
eg. can call 8 digit numbers fine but does not call 10 digit numbers.
I have looked at as many settings as I can find and cannot see anything.
Using VG 5.2.5049, D4-PCIU Dialogic card, Win 2000.
Could the pabx have restriction on the outgoing lines?
Thanks,
Brett
There are no restrictions on the number of digits in the outgoing number
Quite possibly.
If you think that it's VoiceGuide that's not dialing all the digits then please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened.
[Log]
VoiceGuide=10
TapiWrapOcx=10
