Recording Over Sound File
I keep having problems with recording over sound files. Sometimes the program tells the caller there is an error and other times the computer completely crashes reboots (which is very annoying).
I have figured out that if I want to update the message that plays, I have to save a completely new file and give it a new name. This would not be so problematic if I had just one module calling the sound file; instead, I have several modules that reference a single sound file based on various access codes. So when I update the sound recording, I have to change each module that references that sound file which sorta defeats the purpose of a nice tight script.
Has anyone else encountered this problem or is it something specific to my computer?
I have a Broadxent Model: 3631 Modem in a Windows XP
What sort of an error are you getting?
If your computer crashes then it looks like there is a problem from inside the modem's drivers themselves - which are privileged to run at a security level that allows them to perform tasks that can result in a crash...
VoiceGuide itself cannot cause the computer to crash as it is running at an 'user application' level...
What sort of errors is VoiceGuide informing you about?
