Need New Pci-x Dialogic Card
Need to purchase a new Dialogic card that will fit in a PCI-Express slot
Was using a D/4PCI-EURO Dialogic card but recently moved to newer server hardware (HP DL-380) and the card does not fit into the PCI Express Slots
The specs of the PCI-X interface on the DL380 G4 server are here:
http://h18000.www1.hp.com/products/quicksp...6/12028_div.PDF
http://h18004.www1.hp.com/products/servers...ers/pci-express
Can you confirm whether D/4PCIUF or D/4PCIU4S will be suitable.
Also would the EICON - Diva Server Analog-4P (306-232) be suitable.
We'd recommend using the 'Dialogic' branded cards.
Just make sure when you are ordering it that you are getting a PCI-Express version, and not the 'normal PCI' version.
The 'PCI-Express" versions are usually labeled with a little "e" at the end of the name. eg: D/4PCIe
